Omega alignment query
Started by Webby the Bear, 28 April 2016, 19:27:53
Webby the Bear
Evening guys.
So. I got the omega on the alignment rack a little while ago due to the car wandering. It turns out the front and rear toe angles were out.
I adjusted the front but rear track rods were seized solid. I'm shortly going to be buying new ones so that will!be all sorted.
However on the motorway the car is definitely improved. But it still feels a touch "wandery". Nowhere near as bad as before. However is it just cos the rear toe is out causing it?
RIP Paul Lovejoy
biggriffin
Quote from: Webby the Bear on 28 April 2016, 19:27:53
Evening guys.
Tyre pressures to high.,
Hoof'land storeman.
Webby the Bear
Quote from: biggriffin on 28 April 2016, 19:37:48
Evening guys.
No mate. Tyre pressures set yesterday to spec. Wandering experienced today  :y
RIP Paul Lovejoy
frostbite
Any uneven tyre wear?
I had an osf inner edge wear that caused me to correct the steering every few minutes
e46 325i se - 1.8vvti avensis liftback
Webby the Bear
Quote from: frostbite on 28 April 2016, 20:10:32
No mate. Tyres are new this year (all 4). No wear as yet. And no oddities.
Also new wishbones as of this year too.
It must be the rear toe being out surely?
RIP Paul Lovejoy
Stargazer57N
Are the Shock absorbers OK as that can cause wandering especially on uneven/potholed roads.
Webby the Bear
Yes mate all shocks good.
The fact that the toe is out, albeit at the back, does that not scream wandering?
RIP Paul Lovejoy
Could also be a shit road surface :D
T.m.f
1996 300tdi manual discovery,the weekend mud toy and tin tent tower
The devil child ,aka mk2 2006 1.6 tdci focus
terry paget
For decades I have suffered wandering and twitchy steering after changing track rods. Garages adjusted the tracking with optical gear which improved the steering, but left the steering wheel off centre on running straight ahead.
I devised my method of front wheel alignment about 10 years ago. It's not rocket science, just common sense, on every occasion works first time, and results in a car running straight and true with steering wheel centred, no wander, no twitch. I commend it to the forum.
On publication here it was promptly condemned by Chris and Al, who feared damage to wishbones. In 10 years, running six Omegas, I have suffered no wishbone damage. Supported with wood on axle stands right at the outer end of the wishbones, they ain't stressed.
In the unlikely event of rear wheel toe being out it would be spotted at the same time, and could be corrected, if the adjusters would move.
Diamond Black Geezer
The issue we found on adjusting the geometry on my old girl - which I was in the garage watching him do it, nattering - was upon altering the rear track rods, how little change in the camber was made. Adjusting the rear track rods from all the way one way, to all the way the other accounted for something like 0.2 change in camber only.
I have a ridiculous 3.2 or thereabouts rear camber, so all we could do was make the toe correct. But rear camber is still miles out. No adjustment of the track rods alters it by a meaningful amount.
Have to say she feels fine to drive. With the wandering feeling you're experiencing, there is the servotronic steering which gives a 'dead zone' in straight ahead position, this is as far as I'm aware designed that way. Could it simply be this you're experiencing?  :-\
Webby the Bear
Thanks for the input terry and dbg.
I'm in the fortunate position that my camber front and rear is bang on. Therefore when I get my new track rods I should be able to adjust the toe and not alter the camber too much. Obviously the opposite to what you need, dbg.
Maybe a better way of putting it would be..... What symptoms other than tyre scrub would rear toe being out cause? If one if the answers is wandering then I know I just need to track it up and touch wood all should be good. If it's not then I need to look elsewhere  :y
RIP Paul Lovejoy
When you say front camber is bang on........what is bang on?
Webby the Bear
Well, ok, when I say bang on I mean in the green. But when I did the alignment my only concern for that day was doing the toe.
RIP Paul Lovejoy
And Mr The Bear, the rear camber is the issue I mention above ie: you alter the toe n rear camber simultaneously; as one alters, so does the other. As has been said elsewhere, the rear camber is a compromise.When I got mine done, best we decided was at least have the rear toe spot on, to the minute, rather than have the toe wildly out, in a futile attempt to make the rear camber right.
