Omega 2,2dti experiences?
Started by MonzaGSE, 30 April 2016, 11:08:49
MonzaGSE
Hi. Im thinking of buying an Opel omega 2,2 dti. The car has little rust and looks good. Have no experience of diesel omegas though. Is the 2,2 diesel a good engine? Is it Opel/vauxhall or isuzu engine? The car in question sometimes have eml light on. Is it any common issues with these? I understand its obviously slower than the v6 but since its gonna be a daily driver for someone who just got their license i guess thats ok:)
Intakes and EGR gum up, need regular cleaning.  Fuel pump failure isn't uncommon, and will write the car off...
Quote from: TheBoy on 30 April 2016, 11:13:50
Out of interest - why does it write the car off?
I know the pumps are coded, but I'm sure this is the case with many other diesels
Not disagreeing, just like to learn why?
I'm guessing maybe it's often not financially viable to repair, as opposed to impossible, due to the labour times around the timing chain etc? :y
The EDC repair isn't usually cost viable unless the car is mint and a keeper.  :y
Magwheels
£130, not that expensive in the real scheme of things.
Quote from: Magwheels on 04 May 2016, 19:10:04
Not seen a "quality" repair under £300, and that's just sending ECU, not pump, so you have all the dangers associated with separating the ecu and pump...
V8S
I had mine from 2007 until late 2015: mishap after cleaning the inlet manifold to try to fix a persistent EGR valve fault (had already fitted new EGR valve so was going through the list).
It was a strong car with very few issues, enabling me to put 120,000 miles on it including Brittany, sideways driving in Scottish snow, beach doughnuts and innumerable trips to the tip.
It just ate up the miles, although now I've got a bargain Picasso HDI the fuel economy of the Omega compares unfavourably. I was getting average of about 33-36 mpg in normal driving. I'd just nudge 41 mpg on a long motorway run at constant speed. In the Picasso (which, despite the Omega's HUGE boot is far more practical) I'm getting mid 50s all day long no matter how I drive.
Problems I had were not really engine-related, though I had a crank sensor go, a couple of electrical gremlins and a pulley break apart. The main problem I had was wishbones and tyres needing replacement. I had the geometry set up properly (not just tracking) several times but it would still go through tyres fast, and the wishbones and bushes seemed to wear out quite quickly. For a few years I made the mistake of putting Eagles on at £120 a corner, which was bankrupting. Mid-range tyres seemed to last longer.
You could get the codes read by a friendly garage to see what the EML is on for.
V8S
One good thing about the 2.2 DTI is there's no timing belt - it's a chain, which means no costly cambelt changes. I'm staring at a £400 bill for a cambelt and water pump change on the Picasso, and it rankles having done 120k in the Omega without that worry.
V8S
Oh, and if you're a new driver, the insurance group on Omegas is quite high I think. I may be wrong but mine was either a 16 or even a 20. I can't remember now.
Even for a driver in his 30s with only one SP30 on his licence and living in a very good postcode, insurance for my 2.2 DTI Elite saloon was £400+ a year. I got that down over the years to about £300 without SP30 but that was shopping around diligently. To put that in perspective, my TVR costs about the same to insure and that's 4 litres.
V8S
omegod
Pretty sure the pumps aren't coded , use the same part number obviously , I've sold a few and never had an issue
Bojan
That engine is not common rail, which is good for durability and long term use.
It is not so sensitive to lower quality fuel, and in general more roboust.
Downside is that it's a bit loud and has a 'tractor-like' note.
The pump it self is not an issue, the control unit on the pump fails. New pump is outrageusly expensive.
However, control unit can be repaired, but it needs to be done by someone who really knows what he is doing -> control unit needs to be opened, electronic components replaced, and (this is very important) unit needs to be resealed like OEM.
henryd
Quote from: V8S on 02 June 2016, 11:42:46
That's a lot for 3 hours work,the belt kit and water pump are cheap for these nowadays so shop around a bit :y
other rides
I bought mine for a little over £400, ran it for 4 trouble free years and when it did start to play up I broke it for spares and made my £400 back. When they're running well I would say they are arguably the best all round Omega but when they start with problems they can be a right PITA
V8S
The 400 for the Picasso can belt is including labour. No way would I take on that job.
