Win10 question
Started by TD, 02 May 2016, 17:14:14
TD
Ive managed to break it somehow..
Before if I had Edge open and then started another program, the new program (ie calc) used to open over the top of edge.
Now the new app opens behind Edge.....so to get to it I have to minimize Edge to see it....
Its like Edge has a setting 'Always on top', but I cannot find any such setting  :-\
What have I managed to do??
There are fancy utilities to do this, so check running processes.
AFAIK, no setting in the core OS
zirk
Calculator, here you go -
      Option Explicit
      Dim THandle As Long
      Private Declare Function BringWindowToTop Lib "user32" (ByVal _
         hwnd As Long) As Long
      Private Declare Function FindWindow Lib "user32" Alias _
         "FindWindowA" (ByVal lpClassName As Any, ByVal lpWindowName _
         As Any) As Long
      Private Sub Form_Load()
         Command1.Caption = "Run the Calculator"
         Command2.Caption = "Find Calculator's Handle"
         Command3.Caption = "Bring Calculator To The Top"
         Command2.Enabled = False
         Command3.Enabled = False
      End Sub
      Private Sub Command1_Click()
         Dim X As Long
         X = Shell("Calc.exe", 1)
         If X <> 0 Then
            Command2.Enabled = True
         End If
      End Sub
      Private Sub Command2_click()
         THandle = FindWindow(vbEmpty, "Calculator")
         If THandle = 0 Then
            MsgBox "Sorry, the calculator is running"
            Exit Sub
         End If
         Command3.Enabled = True
      End Sub
      Private Sub Command3_click()
         Dim iret As Long
         iret = BringWindowToTop(THandle)
      End Sub
;D ;D :D :D ;D ;D
TD
A reboot fixed it  :y
But that doesn't explain why  :-\
