I wonder why I hate having anyone having to do stuff to my cars!!!
Started by Crazycarzowner, 03 May 2016, 16:24:17
Crazycarzowner
Well I never found the electrical fault on my Disco and having being somewhat disabled by my glass-back and being off work I thought 'Sod it, I'll get an auto-electrician in'. Got details for one who advertised local, had some good reviews & lives literally 3 miles away from me and gave him a call. Booked him for last Tuesday afternoon..........never showed. Rang him at 6pm and he said he was stuck in traffic??? (why could he not just contact me to say he either he'd be late or he couldn't make it. Anyway I thought I'd give him benefit of doubt & re-booked him for last Friday and he said (Quote) "I'll make it my first job" Friday morning came...........and went........NO electrician!!!!!!! GRRRRRRRRRRRRRRRRRRR!!!
Why is it there are no reliable workmen around these days???
It's everywhere, when looking to get my driveway extended I must have rung 20-30 companies. Some never bothered to pick up the phone, most that did gave crazy prices. I booked around 12 companies to come visit and quote me, about 4 turned up.  ::)  >:(
T.m.f
1996 300tdi manual discovery,the weekend mud toy and tin tent tower
The devil child ,aka mk2 2006 1.6 tdci focus
Crazycarzowner
Its on the Discovery TMF, I think I posted it on here a while back. There are all sorts of weird things happening. The interior lights  stay on and will not extinguish unless you turn them to the permanent OFF position i.e. they don't do the auto on when you open the door or blip the alarm and turn off 30 seconds later, also the ignition light on the barrel is constantly on.
Before I ooops-up me back I checked -
The door switches and replaced them all work fine. chased the wiring through the doors & looked for chaffing, all ok
Relays, also fine.
Then asked the Landie forum for advise, that pointed me towards the Multi-Function Unit which controls that specific circuit. That works fine, got a replacement from a scrapper (which worked fine before I removed it from rotting car) swapped it out, still fault occurs.
Checked the fuses, again ok.
Then even more strange, when I pulled the radio fuse, a 10 amp one, which does radio/ cig lighter / auxillary lights, the radio STILL worked????
Got the RAVE CD which is the electrical wiring charts for the D1, chased the wiring to where they are spliced/joined and couldn't find any visual faults.
Then did me back in, called it quits and would willingly pay someone to find the fault, if anyone can be ar$ed  ::) ::) ::)
Crazycarzowner
Quote from: Nick W on 03 May 2016, 17:06:39
Quote from: T.m.f on 03 May 2016, 16:49:02
Whats the electrical fault?
It's a land Rover
True  ::)
Even if I remove the bulbs and leave the battery connected, it kills it within an hour or so, I had a new one put on it last year and its completely killed it, it won't charge now  :'( :'( so had to get another new one
b4ndit
you can try this guy but it may be a bit far for him but he is mobile and he rewired an american chevy truck for me his name is Mark Butler 07803900058 is a good guy and if he wont come out that far may be able to point you in the right direction worth the phone call :y
Terry
T.m.f
Join up to northants 4x4,you will have to post 3 times in newbie section before you can access forum and ask on there,im pretty sure you will get the right answer for faults,there is a lot of members clued up on the disco faults.  :y
Crazycarzowner
Cheers for that b4ndit, but I think Chester to here will be at least 100 miles round trip for him.
To be honest, after me crawling around under the dash and looking aimlessly at wires  :D :D :D (I can follow the path, test wires change bulbs etc.) I'm gonna try to get a Pro to sort it. I hold my hands up and will confess that I'm no good at sparking.  :(
minifreek
Might be a long shot, but something rings a bell with your fault and the headlight switch....?
D.I.L.L.I.G.A.F...
b4ndit
Quote from: Jasonm on 03 May 2016, 17:24:55
no problem just a thought :)
hoody
I don't know what model you have but I had strange electrical problems due to fusible links in the engine bay,Google is your friend,behind the battery running up to the bulkhead,just solder that breaks connections and causes weird problems
Crazycarzowner
minifreek - thanks but headlight switch swapped for another (same one I robbed acquired the MFU from) same result :-(
hoody - its a V8 Discovery 1. Fusible links checked all appear  ::) in order.  :'( :'( :'( :'( :'( :'(
I now (hopefully) have an Auto-electrician attending in the morning, fingers crossed!!!
Crazycarzowner
Well, good news & bad news.
Electrician has been, tested all circuits and has found the cause of the problem. Bad news is its the alarm ECU thats FUBARed  :'( :'( :'(
b4ndit
try this guy Graham Bell very good and may be able to repair yours Call us: 01244 813 321
gbellcars@hotmail.com  :y
