engine warning light 2.0 16 valve automatic omega
Started by para1, 06 May 2016, 09:28:07
para1
  COULD THE ENGINE WARNING    INDICATE  HIGH CO 2 EMMISSIONS>>> FAILED TEST ON THIS EVEN THOUGH NEW CAT FITTED    SENSOR TESTS CAN NOT FIND  ANY FAULTS
Bojan
Do you know what codes do you have?
Have you done the 'paperclip test' or had the codes read by diagnostic tool?
Usual cause of failure is not the cat, its more often than not the engine is not getting to temperature or the ECU thinks its not at temperature so the injection system is not in closed loop operation.
So check the thermostat and ECU temp sensor as a starting point.
para1
    Thanks Bojan>>>>>>No codes indicated on diagnosis... None on Paper clip  test
para1
Thanks Mark  Have checked Thermostat...OK>>>>       Where do I find ECU  temperature,?
frostbite
e46 325i se - 1.8vvti avensis liftback
Quote from: frostbite on 08 May 2016, 08:36:28
Quote from: Harris K Telemacher on 07 May 2016, 19:16:12
Coolant bridge at back of heads :y
LOL on a valver?
Ok pedant: Head(s)...
Coolant bridge on petrol Omegas is in the same place regardless of number of heads/cylinders/valves...
para1
    THANKS      HARRIS K >>>>>>>Replaced sensor  Negative result  However  on retest Engine on idle  Failed CO 2 >>>>>  but on high rev test  passed  = no mot  cert issued. :'( :'(  Help,  which way to go now  ?
para1
Stargazer57N
Quote from: para1 on 11 May 2016, 09:13:13
Unless you own a gas analyzer and a computer that will give you live engine reading you have no hope  finding the problem. check the obvious i.e vacuum leaks broken/loose sensor wires/connectors, air leaks on the inlet. Apart from that you'll need to put it to a garage my friend. Or spend a fortune on MOT's and retest's.
frostbite
#11
Quote from: Harris K Telemacher on 10 May 2016, 23:18:35
LOL on a valver?
Oh snap!  Don't mind me I was thinking of the oil cooler in the valley,  I'm such a douche
Mine also failed on emissions. Due to the sheared studs but they done a second test with lower rpm and it passed with a leak advisory
