Corsa C rear wiper motor cost
Started by Webby the Bear, 08 May 2016, 18:30:24
Webby the Bear
Wifey's Corsa C's rear wiper motor has packed up. I can't get one for under £160 and that's on trade.
Anyone know why they're so stupidly expensive and where I can get a cheaper one from? Otherwise I'll be forced to try a £15-20 eGay special.
Cheers chaps
RIP Paul Lovejoy
EMD
Corsa forum boys quote :
Quote.Had similar problem with my rear wiper ...Intermitant fuse blow! Checked the wiring in the rubber tube by the tailgate hinge
and found a couple of broken wires...... joined them up with connectors....problem solved
Quite a few motors on eday .
Omegatitis
Yes they rarely actually fail, usually a wire break
henryd
Quote from: Webby the Bear on 08 May 2016, 18:30:24
Cheers chaps
Ecp are £132 trade for a rear motor although you should be able to screw them down a bit more :y
other rides
Webby the Bear
I checked it for voltage and it gets battery voltage when switched on. My electrics knowledge ain't all that lol but could I still see 12v at the connector but then there's a short on the ground side?
RIP Paul Lovejoy
Webby the Bear
Cheers for that Henry. Sadly we aren't allowed to order from them. Orders from our boss  :-X
RIP Paul Lovejoy
zirk
Cheers chaps
For the sake of 20 quid against 160 new, I think I know what I would be doing, they either work or they dont.
I dont know this for a fact but guessing Tigra, Astra etc from same year would have the same part number and so would widen your search.
Webby the Bear
Thanks Zirk.
I think I'll check all the wiring first. I presume it's the standard wire breakage where the rubber cover is in the boot area where it bends / gets caught up etc?
If not I'll get a twenty quid spare  :y
RIP Paul Lovejoy
Steve B
A little off topic  ::)
What site is there to read about stripping a rear door down on a 14 plate corsa.
I need to replace the post between the rear door drop and door vent
Steve B
Quote from: BIGtime on 11 May 2016, 22:38:28
Thank Al that will do me.  :y
:y I presume rear door will be similar...
Steve B
Yes think so...just wanted to see modern day fixings..(owing to they like to hide them) but not much has changed... still the horse shoe clip on the wind ups then  ;D  :y
