LSD options
Started by Bojan, 10 May 2016, 10:18:54
Bojan
I'm struggling to find a solution about the LSD for my MV6.
They are really rare, and when they do come up, price is ususally over 300€.
This wouldn't be so bad if they weren't friction plate type -> as this are 15+ years old units, they could be badly worn out.
So, could a LSD from some other car be fitted?
Perhaps there is some 'hack' for using LSD (or at least the internatal, keeping my CW&P) from another car make.
I'm affraid that in the end, I will get an LSD from a company named 'Lincoln electrics'  :D
Diamond Black Geezer
No doubt anyone who has an LSD fitted will cry great confidence and pleasure about how brilliant it is, however, I posted an article a while ago on here. A group of automotive engineers got hold of an old Omega, which had done about 70k (miles) and the 'limited slip' side of things was practically worn out, and showing negligible difference between a standard diff.
A refurbished/rebuilt will cost many many hundreds, there are a couple of people on here who can/will do it. That price is actually very good, as the parts to do it alone cost plenty.
As you say, another LSD off something else would seem to be the answer, the final drive ratio being the critical figure, of course. Aside from suggesting something like a Monaro diff (no idea how compatible these are) that's me out of knowledge  :)
steve6367
Quote from: Bojan on 10 May 2016, 10:18:54
I've never driven one, but does it actually make any useful difference in day to day driving if your not a Police pursuit driver?
Quote from: steve6367 on 10 May 2016, 11:28:11
Not on a heavy, low powered, automatic road car. And road LSDs don't actually lock-up very much, so they're not much good for track cars. And as mentioned, they tend to wear out quite quickly so they don't lock at all.
The LSD in my Capri was really only good for smoky sideways exits until changing into second gear. And it didn't do that on the stock 2.8 engine. Fun, but not much actual use ;D
zirk
As most know LSD's were only ever fitted to Police Omegas in the UK, they were fitted to increase power delivery to the rear wheels in various road conditions , wet, snow, ice etc, rather than aid sideways opposite locking around a corner.
Ive driven quiet a few Omegas now with LSD, both Manual and Auto, and they do do what its says on the tin, the Autos can be a bit daunting when it kicks in, but general day to day driving you wont know its fitted. Its got me out of trouble a few time in the hilly parts of Epping Forest when its covered in snow or ice, not suggesting its as good as a 4x4 but certainly has advantages over a normal diff.  ;)
zirk
300 euros sounds about right, the ones Ive sold (known workers from Ex Police) were around the £245 mark, also as you say very rare these days. if maintained correctly and not abused (Drifting  ::)) they should last well into the 100's of K's, but as with anything second hand your always going to get one persons views as 'its working as it should' vs another ones view of 'no, its furbed'.
Another thing to take into account is the actual correct diff ratio for the correct Engine / Gearbox type, ignore this and you may end up over revving at cruising speeds, or under revving and unable to deliver engine torque at required speeds. End of the day horses for courses and the reason for fitting LSD.
Bojan
Yes, 300€ would be a nice price if the LSD is in good condition.
But I don't think I would find one like that  :( :(
Really, when driving moderately, and fast driving and cornering at higher speeds, you can't really see any dissadvantages of the open diff.
Only while taking the sharp turn (on lower speeds, of course) when you press it, sometimes you get the dreaded inner wheel spin (instead of controlable back slide) -> I really hate this.
Also, bad surfaces (gravel, grass, snow, wet tarmac) - there is quite a lot of wheel spin.
I hate the fact that I can't be sure will it start spining the inner wheel, or the back will start to slide when I boot it (I want it to drift when pressed enough).
I'm affraid that if i weld the diff, it will be hard to use it as normal car (understeer in corners when driving like a normal person is my biggest worry).
To put it short -> I don't want to make it a 'drift car', but want it to be 'driftable'.
terry paget
My Peugeot 505 GTI family estate came with one as standard, and it was useful on ice and snow. I have owned many (8?) ex-police Senators, but none came with LSDs, nor did my 2 ex-police Omegas. I suffered 2 whiny high mileage diffs on Senators, which I replaced.
I have the impression that the ABS system on later Omegas is supposed to brake a spinning rear wheel to improve traction on slippery roads, but have never noticed it. Do other members enjoy it?
I have seen my TC cut in on numerous occasions on my V6 - and I mean 'seen', not 'felt' the only indication the car was helping me in any way was the little blinking light on the dash. Mine is the earlier most primitive 1-channel TC, later two channel, and even later using EBD and braking to keep power application on the road even smoother. However, I'm thoroughly impressed with my 'primitive' system. As basis for comparison yes, my TD's back end stepped out on more than once occasion. TDs weren't fitted with TC.
I personally like a slight occasional 'chirrup' from the back end when really pushing it in a tight bend, telling me a polite 'now, now, stop being naughty, behave.'
Now whether the conclusion to be drawn here is when you have TC there's no 'need' for a LSD, or that this proves that LSDs are useful things and combined with a good TC system only better, I don't know.
Mine really came into it's own on snow/ice, and together with unobtrusive TC/ABS, made the car pretty much unstoppable in even the crappiest conditions 8)
tigers_gonads
Must admit I prefer the old Abs to the newer sort
With the old 3 channel type, if you had wheel spin / abs kicking in, you could feather the throttle a little but the new type tends to retard the ignition first which is a bitch if your trying to get out of a junction sharpish in greasy conditions and you have a slush box  :-\
TBH, I also felt more in control with a peddle connected to a throttle body via a cable too  :-\
I just like that mechanical feel I suppose  ;)
Don't know what the newer 4 channel ABS / ESP is like with a manual box  :-\
Well at least for another 7 days anyway  :D :D
zirk
If youve got LSD fitted, you really need to switch the TC off to get the best from the diff. Its bad enough controling the backend when the diffs locked up, without the TC trying to tell you what to do as well.  ::)
ted_one
I have had a quote from a specialist rebuilder who is recommended by many classic car clubs to rebuild the LSD's on my two MV6's,complete job... drop it off and pick it up £600 a pop so not cheap,but it's wether you really need a LSD :-\
Mr Gav
Quote from: zirk on 16 May 2016, 15:50:53
The MV6 allows a bit more slip before TC kicks in than the Elites, which was very useful on a couple of occasions but I found the TC too blunt, like someone had pulled the fuse for the fuel pump out so I just started driving it with the TC disengaged.
Quote from: nitro on 16 May 2016, 16:59:57
I don`t think it`s worth it on a £400 car unless you really want one.
Bojan
TC on pre-facelift is a bit too rough, IMO. It does the job, but it just doesn't have the smoothnes as newer generations.
More important, elmost every time when it kicks in, my first impression is 'missfire' -> this really gives me the chills in that moment* , so I keep TC off all the time -> I don't need unnecessary stress.
* I'm paranoid about the car, and esspecially about the engine
