Interesting info regarding breather bridge
Started by Diamond Black Geezer, 11 May 2016, 10:13:18
As here:
http://www.cadillacfaq.com/faq/tsb/data/05-06-01-007.pdf
GM were aware that the breathers can/will become blocked, (in the instance above, through icing up in extreme cold climates) they had a cure. What appears to be a separate set of pvc pipe which presumably are a larger diameter than the 'hollows' in the standard breather bridge.
Webby the Bear
Nice find dbg. So the condensation in there freezes in cold weather? Interesting.
Instead of installing the kit couldn't the holes be widened as they suggest? So the 1mm holes become 4mm. Thoughts anyone?
RIP Paul Lovejoy
Applies to the 2003-4 CTS... Might be a specific reason it affects that particular model, and not the Catera :-\
biggriffin
With the small amount, of moisture that would accumulate in those pipes, can't see how it would freeze, with the heat produced under the bonnet. Obviously GM did :o
Hoof'land storeman.
Umderbonnet airflow on the newer car might play a part :-\
When I found it I was more thinking that a larger diameter of pipe would exponentially increase the time it takes for the (what are very thin) tubes in the breather bridge to block with gunky oil.
Flip the logic, and certainly if GM had made all breather bridges this design from the outset, none of us would now be seeking out a one-piece bridge with much narrower tubes.
As you say Mr The Bear, the idea of widening the holes is 'food for thought'. I know the counter is, of course ''just clean your breathers regularly'' etc but as I say, an interesting thought  :)
Webby the Bear
Exactly dbg.
I suppose it begs the question why are they so small in the first place. And would it detrimentally affect anything if they were widened....
RIP Paul Lovejoy
Aye  :y  Given that GM themselves deemed it worthwhile to widen them as per above, I can only assume it wouldn't affect anything. The narrowed apertures down at the back of the engine which also gunk up would strangle any air flow down anyway. Logically, therefore, I'd imagine that the breather bridge itself could be made up of bits of drainpipe without any detrimental effect.  :)
tigers_gonads
Quote from: Webby the Bear on 12 May 2016, 18:21:56
Exactly dbg.
Maybe could cause a slower reaction with the vacuum system due to the larger area that it has to suck on  :D :D
Webby the Bear
Lol whilst amusing you raise a good point. Who knows
RIP Paul Lovejoy
