Information display
Started by Chief972, 11 May 2016, 18:09:41
Chief972
Hi I'm wondering should the information display screen show the radio channel/frequency when the radio is on as when I switch mine on the date goes of to a blank screen the temp is displayed and I know it's not the bulbs as when the radio is of the date is displayed. The only thing I can think of is there is a parrot Bluetooth kit installed when I bought the car so maybe they unplugged something. Thanks
Which display do you have? MID, GID, CID?
Chief972
I have no idea lol it's 2001 2.2dti
Is it a factory fit radio, or some aftermarket tat?
frostbite
If it's aftermarket then you need to cut one of the wires to the display although I can't remember which one
e46 325i se - 1.8vvti avensis liftback
steve6367
Quote from: frostbite on 12 May 2016, 11:36:16
Problem with that is it also stops the salon ariel amplifier being switched on   ???
Quote from: steve6367 on 12 May 2016, 13:16:28
Problem with that is it also stops the saloon aerial amplifier being switched on   ???
Not if you make the disconnect at the rear of the display (not the radio)  :y
steve6367
Interesting - any more specifics? (I tried and failed a while ago!)
Colour at display?
I seem to recall its the same colour wire as you disconnect at the radio, the aux feed that drives the Aerial amp is also fed to the display to indicate the radio is on.
White Red from memory...
