subframe bushes
Started by pauls, 12 May 2016, 19:56:50
pauls
Where is the best place to buy these from. Please
Quote from: pauls on 12 May 2016, 19:56:50
Donut ones?
pauls
pauls
If going poly ..what do you ask them for. monaro?????
Quote from: pauls on 12 May 2016, 20:46:51
Pedders EP1145, Monaro rear end pack (Harrop diff). Should be £99 +postage from Monkfish, buying from Pedders direct and they're £120+ :y
pauls
Bojan
So, Monaro (which one) rear donut bushes fit Omega?
As I was trying to source poly rear bushes, but never found them.
I'm under impression that fiting stronger (poly or similar) donuts is a single most effective mod for making rear end mor firmer and 'sharper'. Because the OEM donuts do really flex quite a lot under load.
Quote from: Bojan on 13 May 2016, 10:19:32
Quote from: Harris K Telemacher on 12 May 2016, 20:56:36
Vega
Quote from: Harris K Telemacher on 12 May 2016, 20:42:20
Febi for normal, Monkfish for poly :y
Is there a special reason for Febi?
Quote from: Vega on 14 May 2016, 08:31:44
They're readily available.
biggriffin
#11
I fitted febi in January, cost £20. Pair from www.vauxhallworldparts.com
Hoof'land storeman.
Vega
Last time I used Lemförder.
I fitted now poly bushes, driving is very firm but there is more noise and vibration inside.
Quote from: Vega on 14 May 2016, 18:26:11
Some NVH is the trade off when deciding between softer, floaty rear end and a more controlled approach ;)
Depends if you cruise around at 60% of the speed limit or prefer to drive to the capabilities of the chassis...
