Cork ?
Started by EMD, 13 May 2016, 14:20:51
EMD
Cork rocker gasket removal that's gone hard and welded
itself to the head  :( What will soften it so it can be removed  :-\
Omegatitis
Diamond Black Geezer
Not based on any personal experience, sadly, but surely left in some hot water for a period of hours/overnight would help / cant hurt?
EMD
Ah i should of explained that a bit better dbg , the gasket is still on the
engine around the cam .. the actual covers is off and clean .
Omegatitis
Ahh booger. Slightly more faff immersing your whole car in hot water.  :)
I'd imaging a carefully sharpened paint scraper, or similar (I'm sure you can actually buy flat blades specifically for scraping off things, but forget their names, BnQ will sell therm)
Maybe even something like a cheap n cheerful Rolson/other paint scraper, ie: made from cheap n nasty soft metal that won't mess up the mating surface of the cyl head...
Mister Rog
Damn ! I thought this was going to be about the pros and cons of cork Vs screw caps on wine bottles   ::)
Oh well . . .
"The desire to be a politician should bar you for life from ever becoming one." Billy Connolly
shave it off with a honed wood-chisel.
You don't need a good quality chisel for this, and you definitely don't want to let anyone see you using a good one for it :o
This is what Poundland is for.
EMD
Tried a scraper but the cork is rock hard  :(  Had to fight it to get the
cover off   . Will try the chisel cheers nick .
Omegatitis
I knew that a sharpened scraper had a technical name.... 'chiz-ull'  ;D :D ;D
Quote from: EMD on 13 May 2016, 14:41:37
Try harder ::)
