MOT passed
Started by pernix, 13 May 2016, 23:19:20
pernix
AD51DYX  lives for another year ;D.....no advisories either.........took front to rear brake pipes and a rear spring (changed both :y) to get there
Tick Tock
Great stuff. I join you in your happiness, as my 17 year old Vectra passed its test this week too  :y
Omega 2.5 V6 Facelift Estate.
EMD
Its amazing how many of our cars pass with no advisories given the age they are . Well done  :y
Omegatitis
Well done indeed :y
Quote from: EMD on 14 May 2016, 03:53:32
Er, not really ???
It's a simple matter of preparedness and a bit of pride... fix faults as they arise along with a bit of preventative maintenance and you'll have no problems...
Treat the MoT as an annual fault finding exercise and you will be presented with a long list of stupid fails that could easily have been avoided/preempted ::)
Wiper blades, washer fluid and tyres should never, ever, be seen as advisory items let alone failures. Simply inexcusable imho :-\
I am already concerned about the Bullet's next MOT, which is next year  :-[
EMD
Quote from: TheBoy on 14 May 2016, 09:01:57
It will be fine  ::)
Omegatitis
terry paget
Quote from: Harris K Telemacher on 14 May 2016, 07:40:16
Well done indeed :y
Er, not really ???
Emissions are the one item that worry me. My 2 litre Omegas, fitted with after market catalysts, would fail year after year and I eventually resorted to fitting a special cat section to them before the test. They are all scrapped now, but I have two 2.2s and one failed last year on emissions (lambda of 1.12), eventually cured with a change of MAF.
Shackeng
I only use premium fuel in the 3.2, which also seems to help keep the breathers clean, as whenever I look at them they are spotless, and never had a problem with emissions. The TD gets a dose of Diesel magic and an Italian tune-up before the test, and it always passes emissions. :y
Diamond Black Geezer
