BBQ help
Started by TheBoy, 15 May 2016, 15:42:43
tigers_gonads
I don't know why you don't get one of those LPG ones  :-\
Apparently they go down a blast at parties and with a little practice, the taste of those sausages will blow your garage door off  mind :y  :D
6828
Quote from: TD on 15 May 2016, 18:51:48
A gallon of Tesco's Finest should get a good blaze going  ::) ;D
Indeed it did. Well, probably only about 1/4 of a gallon.  But it wouldn't keep it lit for more than a few mins - to the point of when putting more petrol on, it wouldn't ignite without a blowtorch (ran out of matches)
Quote from: migmog on 16 May 2016, 17:04:46
Quote from: Harris K Telemacher on 15 May 2016, 19:29:58
There's a wire frame which sits in the bucket and allows plenty of airflow around the fire bucket...
Those are best used with self lighting charcoal bags :y
no i think what you have there is the inner bucket which sits in another bucket with bigger air holes.  i guess the idea is the inner bucket is to be a bit thermally insulated and get very hot, the small holes will let it last longer.
if that image doesn't work try www.ebay.co.uk/itm/262254583401
That looks to be exactly it.
I can't see how it can draw air in??
Quote from: TheBoy on 16 May 2016, 17:27:47
That's because that Migmog cant is trying yet again to make me look stupid rather than answer the actual question... >:(
Pics to follow... :y
There should be four stampings towards the base of the bucket...
These, in turn, support an internal wire frame...
The fire bucket, as shown in your first picture, sits on this wire frame...
The fire bucket should be drawing air through the four holes in the outer bucket and then through the five holes in the fire bucket.
No reason why you couldn't drill more holes in the fire bucket, but air supply to the base of it should be perfectly adequate :y
omega2018
yes holes do look small compared to a bbq with the vents open,  i think the theory is it doesn't need as much air supply as the inner bucket is insulated and won't cool down as much so doesn't need so much energy input to keep burning.  so its a bit more difficult to start but when going it should stay going longer.
or it may be that they just saved some money on drill bits or hole stamps when making it :).
tigers_gonads
Didn't it come with instructions  ::) ;D
That is exactly how mine is HTK.
But it goes out after once the flames go (ie, firelighters and petrol run out). Blowtorch will briefly get the charcoal glowing again, but goes out again.
Quote from: tigers_gonads on 18 May 2016, 11:28:34
Yes. Useless.
I would get a chimney starter to get the charcoal going, then tip it in once it's burning well.
Without any adjustment on the air inlet, I'm not sure you'd get enough air to get it lit, without it then turning into a blast furnace that ruins any food that goes near it. :-\
Could try another four holes outboard of the existing four and go from there :-\
Not sure I would add further holes to the cosmetic bucket as it would then lose its function as a container...
How are you fuelling it? Not used mine yet, but thinking it through, perhaps less is more... start small and build it up once established rather than using bags... half a small disposable one might also do it, literally half the charcoal and cut the starter sheet in half and trim to fit...
Will try mine later in the week if I feel upto it :y
I whacked in a few firelighter cubes, and piled up 6 or 7 charcoal lumps around it. It started as expected, and after half an hour or so, went to the grey with a glow. Chucked food on, and it started well, then went out.  Added petrol to get flames again to get the charcoal to start again, but after the flames, it went out again. And again, and again....
Quote from: TheBoy on 18 May 2016, 19:41:48
What were you cooking, a mouse for the cat?
Quote from: Nick W on 18 May 2016, 21:05:06
I was (probably incorrectly) working on the principle that once glowing, you normally spread the coals out to make a single layer on the grate that holds the charcoal up in a traditional BBQ.
As the pictured fuel bucket is only about 7 or 8" across, it was enough to easily cover the bottom.....
Are you using lumpwood charcoal or briquettes?
Briquettes need a lot of heat in them to start them burning as they are quite dense. Lumpwood lights much easier.
Also, using a liquid  "accelerant", especially if air supply is limited, it will burn off above the coals and not get heat into them. I have a supply of kindling wood standing in a container of diesel for lighting mine. Works every time but smokes "a bit". ::)
