BBQ help
Started by TheBoy, 15 May 2016, 15:42:43
I have an emergency el-cheap Tesco BBQ bucket, but I can't seem to keep it alight.
It will need decent airflow from underneath, won't it?
The "basket" for the charcoal only has 5 tiny holes, 4 2mm, and a central one about 4mm, as shown in pic:
That's not going to allow enough air, is it:
TD
BBQ lighter fluid I think will help get it going.... :-\
These type of BBQ's, the charcoal is usually soaked with fluid, which if you have had it some time, has probably all evaporated.
LFF64
I wouldn't think so and if it sat on the floor they will be even less use I would drill some holes around the outside low down to get the air flowing through
Rods2
I would say you want more ventilation and ideally some sort of steel mesh to keep the coals above the base and blocking the holes. This is how my cast iron BBQ works with no problem lighting and burning the brickets right the way through. :y
Alternatively, you could, err..... maybe not. :-X
TD
Quote from: Rods2 on 15 May 2016, 18:02:24
Alternatively, you could, use petrol :-X
Fixed for you Mr Rods  :y ;D
A gallon of Tesco's Finest should get a good blaze going  ::) ;D
There's a wire frame which sits in the bucket and allows plenty of airflow around the fire bucket...
Those are best used with self lighting charcoal bags :y
zirk
Oh Christ, another potential big bang.
Webby the Bear
Get your can of brake cleaner out  ::)
RIP Paul Lovejoy
Webby the Bear
Quote from: Webby the Bear on 15 May 2016, 19:48:32
Just saw this was a thread by TB.....scrap what I just said  ;D
RIP Paul Lovejoy
omegod
Just put it in the garage, all will be fine  ;D
biggriffin
Can we but see the headline's on the local news :o.
My mum always told me not to play with fire.
Hoof'land storeman.
Gaffers
Who let you buy a BBQ?
Steve B
Lookslike a snare drum
Rods2
You've got an LPG car, have you ever thought of converting your bucket BBQ to the easy to use convenience of LPG? Safe as houses, what could possibly go wrong? ::) ::) ::) ::)
omega2018
#14
Quote from: Harris K Telemacher on 15 May 2016, 19:29:58
no i think what you have there is the inner bucket which sits in another bucket with bigger air holes.  i guess the idea is the inner bucket is to be a bit thermally insulated and get very hot, the small holes will let it last longer.
if that image doesn't work try www.ebay.co.uk/itm/262254583401
