P0135
Started by manolo, 19 May 2016, 08:31:02
manolo
Hi
please, need advice.
get error P0135 (O2 sensor heater circuit multifunction bank 1 sensor 1) After switching place with other side O2 sensor (bank 2 sensor 1) get the same error P0135?
any advice?
THX
frostbite
You have a duff sensor that needs replacing
e46 325i se - 1.8vvti avensis liftback
manolo
Quote from: frostbite on 19 May 2016, 08:34:44
and why didn't I get new error code P0155 (O2 Sensor Heater Circuit Malfunction Bank 2 Sensor 1) ?
More likely a loom fault if switching sensors changes nothing :y
manolo
y26se
whats mean loom fault?
There's likely a break in the heater wire to that particular sensor position.
Probably at a crimped connection in the cable tray next to the plenum, assuming the heater circuit is the common feed :y
