Don't buy a car on the MOT alone
Started by Stargazer57N, 21 May 2016, 01:47:21
Stargazer57N
Since buying my first ever Omega a few weeks ago I've been trying to sort out the noisy diff, possible wheel bearing noise,  handling and pulling to the left problems. Changed the rear shockers and diff oil which helped but still felt that there was something not quite right.
When to check the tread depths on the tyres today as I knew two of them are wearing a little , but still OK for a few thousand miles yet though. But check this out! I noticed the tyre sizes, OSF & NSR 225/55w16 XL NSF & OSR 215/55w16 XL. It's no wonder the diff was sounding noise as it was trying to cope with the 5.5mm difference in the rolling radius of the tyres.
The car was MOTed before I bought it and this sort of thing makes me really P##ses off as it make a mockery of the MOT system, and of good MOT testers, of which I like to class myself as one. Plus it gives no a confidence view of garages to the general public and gives all mechanics a bad name.
I'm really considering applying to the DVSA for a job as a VI as shady dealers like this need shutting down.
Rant over, on the plus side diff and possible wheel bearing noise has gone, so will the road noise when I get shot of the eXtra Load tyres.
Presumably you actually looked at it when you collected it... ::)
Would strongly recommend retaining XL tyres as it's an estate,  even more so if it's used for towing...
BazaJT
Must say out of all the cars I've ever bought,while I've looked at tread depth when picking it up I've never checked tyre sizes!
Quote from: BazaJT on 21 May 2016, 07:15:18
They would look odd on the rim...
Quote from: Harris K Telemacher on 21 May 2016, 08:28:09
Probably not enough to notice TBH :-\
Quote from: NewbieDocker on 21 May 2016, 09:00:50
Especially as you can't see both sides at the same time.
Opposite corners unless I read it wrong :-\
An MOT is not a measure of how good a car is.  Its there to remove certain obvious deficiencies by either informing or enforcing the owner rectifies them.
It is not a guarantee of safety or roadworthiness...
Shackeng
I was on an orchestra tour half way round Europe with a Tristar, when engineers arrived from London to change a wheel which had been fitted with the wrong type of tyre. :-[ I was happy with tyre conditions, which is critical, but checking tyre details was not normally included in the walkround! :-[ :y
henryd
Quote from: Stargazer57N on 21 May 2016, 01:47:21
Who's to say the tyres were not the ones it was mot'd with ::)
other rides
Vicar
I had similar on a vectra I bought many moons ago, listed with "abs and tc lights keep coming on" bought it for peanuts.  :)
When I got home I changed the front tyres for correct size so they match the rears. Usual 65profile on the rear but 55 profile on the front. Never had the lights ever come back on. ;D
Quote from: henryd on 21 May 2016, 12:52:09
Got that T shirt :-X
OP has started going through replacing bits before noticing, yet claims to be a tester... then gets all uppity blaming everyone else when he realises that he's potentially spent good money on a dog... ::)
Sorry, but does make I chuckle...
baggers
Seen that done a few times.
Stargazer57N
[/quote]
The seller told me the tyres were changed for the MOT obviously the tester didn't check them on the retest.
Harris I only replaced bits that needed changing anyway, and my Omega is definatly no dog. I wasn't getting uppity I was just posting this as a warning to others when buying cars.
Caveat Emptor springs to mind ::)
Post read as a dodgy MoT rant though...
