Moody 3.2 with 0150
Started by 05omegav6, 04 June 2016, 17:58:46
Car has just had replacement loom fitted...
Developed 246 misfire. 246 coilpack loom repaired, (ground wire was corroded, so bypassed and replacement tail fitted)
Now runs, but lumpy. No light on.
After scanner shows no codes, but pedal trick suggests 0150.
Revs ok, just idling like the alps.
Bank 1 trims are... Short 25%, Long 0% 02 sensors both at 0.015-20
Bank 2 trims are... Short -25%, Long 0% 02 sensors at 0.850
Any ideas?
biggriffin
Had this couple years back, turned out was a faulty coil pack, and spark plug, also flashed up  maf code aswel.
New 135 and set of plugs :y
Hoof'land storeman.
Throttle body clicking away.
Unplugged Maf and idle settled, plugged back in and ok, unplugged it and misfire returned.
Still no Eml/spanner light.
Bank 2 sensor 1 replaced and no more 0150, so that's dealt with that.
Maf swapped with original one to rule it out... No change, although it showed a higher idle airflow on the live data. 8.5kg/H vs 5.0 kg/h.
Coilpack swapped yesterday to rule that out...
Looking at second loom change... Do also have spare throttle body (original to car) and a spare ecu.
Loom was originally changed to solve intermittent and persistent o2 codes, not the usual 0420/0430.
Change solved the 02 codes, but introduced the 246 misfire  codes, hence the loom repair... Still persistent although no lights and starts ok from cold, getting progressively worse as it warms up.
QuoteBank 1 trims are... Short 25%, Long 0% 02 sensors both at 0.015-20
Quote from: Harris K Telemacher on 04 June 2016, 19:52:17
Have the wires got crossed? Is the 135 wiring plugged into the 246 sensor & visa versa?
biggriffin
As coil pack gets warm, the hair line cracks open(expansion) then you get a misfire. Try a new, coil pack, no cracks.
Hoof'land storeman.
No, cross referenced with original loom prior to fitting and Factory diagrams  :y
Coilpack loom impossible to confuse as plugs are colour coded to the packs... Also 246 plug won't physically reach the 135 pack.
Car has had alot of work done this year, including complete new exhaust with 3.0 cats.
Quote from: biggriffin on 04 June 2016, 20:28:49
Makes sense, previous pack is very tidy second hand, current one is, I believe, new (I didn't fit it). Same fault with both, ie no change.
Quote from: Harris K Telemacher on 04 June 2016, 20:37:53
I meant the lambda sensor wiring. My reason for asking is that there was a car on the forum that had the fuel trims going up on one bank and down on the other after a gearbox swap. Turned out that it was very easy to mix the wiring up as it is long enough to reach either sensor.
Serek fitted the cats, so wiring was taken as correct. Also, the way the loom runs on an auto, it's almost impossible to get the sides confused as the bank 2 plugs are tied in with the gearbox primary plugs, whereas bank 1 are with the gearbox speed sensor  :y
Just reread your post... Suggestion that the bank 2 sensors are arse backwards?
serek
any news? I know car, and its on going problem there was few sets of lambda sensors fitted to solve p0150
when we was fitting cars other day plugs where marked to make sure don't get mixed up .
Quote from: serek on 05 June 2016, 22:51:55
Likewise when we swapped the loom :y
#13
Quote from: Harris K Telemacher on 05 June 2016, 23:33:53
Any chance of the wires being crossed before Serek saw it?
The thing that has caught my attention is the way that the short term trims are up 25 on one bank and down an equal amount on the other which makes me think that the feedback from one bank is being fed back to the other  and via versa.
Visa versa.........
If it isn't the lambda sensors then I wonder if it is possible for the injector wires to have been swapped? From memory it wouldn't be easy but becomes possible if you unclip the lid on the cable tidy between the two banks of injectors.
