Throttle problem
Started by plym ian, 08 June 2016, 16:19:39
plym ian
What would cause the throttle to just suddenly die so to speak?
I would be driving along then it would just cut out slowing the car up then open up again even though my foot is still in the same position?
2.2 petrol 2001
Diamond Black Geezer
Not a four-pot man, but my initial thoughts would be throttle position sensor? They're drive by wire on these, aren't they?
Yep, it will have stored some fault codes if the DBW throttle has played up. :y
plym ian
Quote from: Kevin Wood on 08 June 2016, 16:35:51
Would the eml come on? Cause it hasent. I'll check for codes anyway
Clean the throttle body & breathers as your first port of call
plym ian
No codes but will try a clean of it :y
