Wanted Bits
Started by gbh, 15 June 2016, 13:10:47
gbh
A few things required for the elite namely the drivers side window switch and rear switch,also Z147 silver trim from base of passenger wing mirror and one last thing the piece of foam from the bonnet nearest the driver.Oh and the aerial which is broken/snapped on the estate!!Thanks
Diamond Black Geezer
I cant remember how easily you can ping apart FL door mirrors, dont recall trying with any success. Obviously anyone stripping them for just the one part then makes the whole mirror incomplete / unsaleable. The norm is to get a whole mirror assembly, which I could supply (Z157, almost identical, half a shade out, many argue indistinguishable) if you don't get sorted on the exact part you require, let me know. Will check 'in stock' for the other bits, too.  :y
Again, if anyone else wants to jump in, feel free.  :)
V8S
I probably have those bits.
Which switches do you mean exactly? Do you need the switch mechanisms from the set of four switches in the driver's door, or do you need all those plus the switch from the rear door?
I have an aerial. No idea how to remove it.
The foam I probably have too. Can you tell me exactly what you need? Maybe a pic with an arrow?
V8S
Just to clarify, I've got a saloon. Don't know whether the aerial is different to an estate.
zirk
Quote from: V8S on 16 June 2016, 16:21:35
Different, no good for Estate  ;)
Definitely won't be able to source an aerial, just to clarify. Thought these were relatively easy to find, though/standard cheap n cheerful thread?
gbh
Its the drivers bank of 4 switches plus the wing mirrors and single rear window switch. I'll take some photos not sure about arrows though!!
V8S
I have the bank of four switches but I'm afraid the coating is a bit worn. They do work though, or at least they did before the car broke. If you PM me your email address, I'll send you a pic.
I also have both rear door switches.
