fob repair
Started by pauls, 22 June 2016, 17:13:44
pauls
Brain dead as usual >:( didnt we have a member who could repair / key fobs
Crazycarzowner
pauls
Thats him is he still running on ebay
pauls
If it will last long enough to next time that Terbert fella gets off his 'arris and organises a Wycombe do, I can bring some switches along and an iron...
Crazycarzowner
Quote from: TheBoy on 22 June 2016, 19:46:44
You turning pink??? Ironing is womens work!  :P :P :P :P
;D ;D
pauls
Just a follow up question on this, what fails on these it is the key not sending a strong enough signal to open the doors or the car itself not receiving it. One of my fobs is good new battery,button good but every so often i have to press and wave it around like a idiot to get the doors to open.other fob is total add it
minifreek
Iv had 3 fobs go faulty on me, and its always been the battery connector....
D.I.L.L.I.G.A.F...
Quote from: pauls on 22 June 2016, 19:58:32
On 2 button, its the battery holder. On 3 button, battery holder and switches.
Remember, the battery needs to "recover" after each press, which has the symptom of reduced range on the 2nd or 3rd press.
pauls
Ah so i was on the right track when i said to myself new fobs needed. :y
pauls
Can i just buy 2 new fobs from martin.
minifreek
No because the new fobs would need programming to your cars ECU... for that you would need programming software and most importantly the car pass....
D.I.L.L.I.G.A.F...
pauls
Quote from: minifreek on 22 June 2016, 21:40:45
ok will sort out sending them upto him to sort out :y
McBandy
IIRC from my days at Vx you can swap the chips over and they will start the car, can't remember if there's a work round for the remote side of it... may be able to press the lock button with ignition on to initialise it but my memory fails me
