Sourcing V6 DBW coil packs.
Started by Migv6 le Frog Fan, 23 June 2016, 11:32:50
Migv6 le Frog Fan
What is the current thinking on the best source for these ? Istr genuine are prohibitively expensive, so some kind of aftermarket is the best option, but which one ?
Tia.
Bojan
Bosch?
OEM ones are made by them anyway.
IME, Bosch unit is 30-40% cheaper that GM OEM one.
biggriffin
Hoof'land storeman.
Migv6 le Frog Fan
Site says "domain name will be up for sale from 04/16". Looks like they may have shut up shop ?  :-\
Will try giving them a call tomorrow.
btc
biggriffin
Ignore that, been there for months,
still trading fine,  :)
Hoof'land storeman.
Migv6 le Frog Fan
Diamond Black Geezer
Is there any issue converting to the earlier coil pack? Fairly sure someone did this. Except for the different shaped holes in the rocker covers, I can see this being the way to go. 'Proper' HT leads will be made for the next fifty years. They can be made in a shed.  :)
Quote from: Diamond Black Geezer on 28 June 2016, 13:38:34
Er no......you have 6 firing pulses on the coil per plug setup and 3 on the DIS setup.......so as much as you might be able to with diode ORing its not guaranteed to work and the ECU might have a hissy fit
Migv6 le Frog Fan
I wouldn't even attempt it tbh. Just want to source a good quality 246 pack for the best price.  :y
Quote from: Marks DTM Calib on 28 June 2016, 14:22:13
Thought it had been done. If I don't ask I don't learn. Fair enough.   :D :)
Migv6 le Frog Fan
Quote from: STEMO on 27 June 2016, 20:10:28
Quote from: btc on 27 June 2016, 19:45:07
Working okay for me  :y
And me
http://www.vauxhallworldparts.com
If you read what it says in the red box at the top of the page - "domain will be up for sale....."
Site says the part I want is available for trade customers ?  ???
Sent them a message - no answer.
Called the phone number - no answer - stuck again.  :(
Migv6 le Frog Fan
Quote from: biggriffin on 27 June 2016, 20:33:44
Just noticed this. Will kepp trying them, thanks.  :y
