97 2.5 TD CDX Estate - Which Head Unit?
Started by Scatmancraig, 25 June 2016, 08:04:31
Yep that's for the CD Changer, if you don't fit another one then i'll buy the bracket off you!
zirk
Looks like the changer place to me, have a look on the other side and see if you can find an Amp (possibly labeled Phillips) or the connections to one, a lot of late PFL CDX (and early Elites) had a 804 HU and separate Amp in place, on the Saloons the Amp was fitted near the NS rear Wheel Arch.
Diamond Black Geezer
Scatmancraig
Quote from: Doctor Golllum on 30 June 2016, 10:44:24
There's nothing on the other side  :-[  I suspect someone had an aftermarket head unit in this car as all of the wiring for the original omega connector had been cut.  Someone has clearly tried to put the original connector back on, but made a hash of it, so I'll be tidying things up a bit before a head unit goes back in.  I guess the CD player that was in it when I got it may well have been the original unit.
Probably a DC022 if mammary serves, if original  ;)
gstylebaby
The radio and changer I have or sale is the ccrt700 from a 1999 mv6. Is this not the one you need then mate?  No problem if it's not. :y
Scatmancraig
Quote from: gstylebaby on 01 July 2016, 21:43:58
Unfortunately, the radio display on the dash is different on that head unit, and an earlier post on here suggests it isn't compatible with my car without modification.
gstylebaby
That's o.k mate no problem you still interested in the speakers?
Scatmancraig
Quote from: annihilator on 29 June 2016, 18:00:46
Here you go
listed as vectra but should be the same.
John
Started to have alook at the wiring today, and immediately there's a problem.
I presume that some of the wires numbered 17 to 26 are there to control the dash display. The problem is that I'm not exatly sure which ones. And as there are 4 that are brown/white, how am I supposed to work out which one is which?  The ones on mine have all been cut, so whilst I know which one is which at the connector end, I don't knew which is which at the display end!
Can anyone help work this puzzle out?
You've got PM Craig. If you like, wait until billing, we'll ream my HU out and you can take whatever photos you like. It's all greek to me, but if you literally copy exactly how my original un-molested wiring is, can't go far wrong.  :y
annihilator
#40
To be honest even if you look at an uncut loom you're going to be non the wiser as all the relevant cables all merge into one loom.
You just need to concentrate on the brown/white wires as per top row of iso connector
17 scl
18 mrq
22 sda
personally I'd just connect the br/white cables until you find the correct combination.
John.
