97 2.5 TD CDX Estate - Which Head Unit?
Started by Scatmancraig, 25 June 2016, 08:04:31
Scatmancraig
What head unit should be fitted to a 1997 CDX Estate?  Mine has a GM CD player head unit that doesn't seem to want to communicate with the dashboard display.  I'm sure it's not the original as in the boot there's a CD changer mounting bracket on the right hand side.  So I'm guessing the head unit would have been a tape player?
I'd like to replace the head unit with something that will talk to the dashboard display properly, preferably an original type if there's any out there at a reasonable cost.  I also need to replace all 4 speakers as they're all completely fubared, butI guess I can probably get those new locally.
frostbite
Best checking the bay for a unit,  there are a few refurbished on there
e46 325i se - 1.8vvti avensis liftback
gstylebaby
I have a radio tape player and the changer and maybe able to help with the speakers. I will find out what the model number is of the head unit and changer so you can check if it's compatible if your interested mate. Unless your after the bose setup then I can not help sorry.
annihilator
#3
You need to hold down buttons 4 & 6 to toggle the different display settings.
8 or 10 digits.to get it to work correctly.
Cdr 500 was a cost option in lieu of car400 rad/cass.
John.
Scatmancraig
Quote from: gstylebaby on 25 June 2016, 09:13:29
I may well be interested depending on cost.  Not too worried about having the Bose unit, I just want something that's original-ish, and that works properly! The radio reception on the head unit that is in it is not good.  I know the old Grundig units fitted to later Senators used to lose the FM reception after a few years, not sure if the ones in the Omega do as well.
gstylebaby
I have found the speakers just got dig out the tweeters and the radio and changer codes once I have found them I will drop you a pm and we can go from there mate if your still interested that is.
Lee.
Diamond Black Geezer
if it's a PFL on a 97, not a MFL (have you got radio buttons on the steering wheel?) then it's the SC804 with Philips autochanger. Same as me  :)
No doubt absolutely worthless... until you try and find one, then they're hen's teeth.
terry paget
On my 2000 CDX estate I have a superb CCRT unit, with 6CD changer in the boot, and it drives a display with an unusual spidery tape face. Pic follows.
terry paget
OP needs to tell us if he's got wheel-mounted audio controls. '97 was crossover year PFL/MFL
OP - what is the last LETTER of your VIN, so we can work out if PFL or MFL
Quote from: terry paget on 28 June 2016, 10:34:15
CCRT700 was only available on 1999 cars, so wouldn't have been fitted to OPs car.  The wiring is slightly unique on the CCRT700 and its unique CART display, so not plug and play into non CCRT cars.  That said, I retro fitted it to my 1998 MV6 briefly, before ripping it out and fitted the rather more featured NCDR1500 - http://www.omegaowners.com/forum/index.php?topic=87632.0
Scatmancraig
Quote from: Diamond Black Geezer on 28 June 2016, 09:11:13
No steering wheel buttons on mine. So guessing its a PFL.
Scatmancraig
Quote from: gstylebaby on 28 June 2016, 08:07:47
Lee.
I am interested in anything that works with the display on the dash. I can't get the head unit on mine to work at all with the display.
