My Garage . . . .
Started by Mister Rog, 25 June 2016, 11:50:06
Mister Rog
Warning. This may upset some of you
I have a huge garage attached to the house. Big enough for at least two, maybe even four Omegas when empty, I've never actually tried that.
On Monday I have some guys coming in to block off a window and build a block wall to divide the garage approx 70% to 30%
The bigger 70% part is for  . . . . . . . . .
A DRUM KIT !!!
"The desire to be a politician should bar you for life from ever becoming one." Billy Connolly
biggriffin
How much space, or how big is the drum kit. I'd go 50/50. Need somewhere to put cars.
Hoof'land storeman.
Mister Rog
Quote from: biggriffin on 25 June 2016, 11:53:08
Well drum kit, plus quite a lot of storage. In the two and a half years since moving a car has only been in the garage once, and only then because there was valuable stuff in the back while we were moving in. We simply never use the garage for cars. I'm not sure but may still be able to squeeze Omega in at an angle if I really needed to  :y  The 70/30 was mainly due to the position of a door and also beams in the roof.
A drum kit?
I'm not worried, you're on the other side of the country and the rain in Wales will help to damp( ;D ) the noise.
ronnyd
Mister Rog
Quote from: ronnyd on 25 June 2016, 13:14:11
Mid life crisis Rog? :o
I wish  ;D
No a "late life" crisis, along with my guitars and amps, none of which I can actually play  ::) but trying  :-[
But hey, still cheaper than a flash car and bits on the side  :y
Mister Rog
This morning the builder turns up around 8.30am (down here it's amazing that they just turn up!)
Radio gets turned on. Some pop music station. "Oh I need to change that" he says. To Radio Talk Sport . . . . . . so I can gloat about England   ;D   ;D
Mister Rog
Well, after a long time an update
Wall built (like fort Knox !)
And, drum kit in place  :y  Brill, making a lot of noise. Omega is outside . . . .  :( But . . .
powerslinky
Looks cool Rog . . .  but hard to guage how much room you have  . . need a wider angle picture.
Is there enough room to get backline amps & a PA set up in there . . if so looks like a good rehersal room for a band  :y :y
Mister Rog
Quote from: Essex Big Al on 08 September 2016, 04:11:18
Hi Al ! Up early this AM. I almost do have a backline, but no PA. This is a public forum so didin't want too much in the picture
powerslinky
Quote from: Mister Rog on 08 September 2016, 04:27:45
hi Rog . . . yer up early  . .bodyclock is all over the place since i've been in hospital .
Understand your concerns about public forum  . . .  :y
It would be worth getting some insulated plasterboard on those walls......it can get chilly down there in the principality  :y
ronnyd
How are the neighbours taking it? ???
Mr Gav
I hope to see something like THIS posted on here sometime soon  :y
Mister Rog
Quote from: Mr Gav on 08 September 2016, 22:04:53
Hummphh, lightweight amateur !   ::)      ::)
