Newbie
Started by atann, 27 June 2016, 18:55:12
atann
Hi guys, just got my Omega on Thursday. A facelift 2.6 auto CDX. Very pleased with the car, but a previous owner has fitted an Sony head unit, which is causing some problems. I am only get sound from the right speakers, nothing from the left ones. I have read the post about the Bose system the car originally came with. Could I put an original head unit back in? Which model would it be? There is only one black plug going into the Sony head unit, do you think the car has been rewired?
A CDX wouldn't have come with Bose.
atann
Quote from: TheBoy on 27 June 2016, 19:05:04
There is a subwoofer on the rear parcel shelf? Was it an option on the CDX?
I don't think Bose was ever offered as an option on any model, but was std on Elite.  It is/was, however, a fairly simple retrofit.
Is there a black shelf bolted to the top of the parcel shelf in the boot?
atann
Quote from: TheBoy on 27 June 2016, 19:10:04
Not sure I'll have to check.
Try the balance settings on the head unit ;)
gstylebaby
Quote from: Doctor Gollum on 27 June 2016, 20:33:12
Second that. Start with the simple things first mate
frostbite
Could be the loom isn't making great contact in the iso block. I had is a while ago where the wires would squash when the head unit is pushed back causing nose sound then when pulled out would work
e46 325i se - 1.8vvti avensis liftback
atann
Quote from: atann on 27 June 2016, 19:13:49
Not it doesn't. I've noticed the the unit resets its self when the ignition is turn off or on?
atann
Quote from: gstylebaby on 28 June 2016, 08:09:57
Tried that and fade.
frostbite
Quote from: atann on 28 June 2016, 18:13:51
That's because the red and yellow bullets haven't been swapped over in the harness. Then the radio and settings will save
atann
Quote from: frostbite on 28 June 2016, 18:45:31
I will have to try that, thanks.
sounds like whoever fitted it did a halfarsed job.
Dave DND
Quote from: TheBoy on 28 June 2016, 20:32:44
Amazing how similar Halfords and Halfarsed can look   ;D
Agree though, sounds like a bad install   :y
Radio & Decoding Technician
www.dndservices.co.uk
atann
Thanks for that, swapped them over saving now.
