Drill and tapping required, Teesside?
Started by GastronomicKleptomaniac, 02 July 2016, 20:33:17
...restoring another 190 and ive managed everything so far, except one bloody brake bleed nipple. Despite my best efforts with a grinder, a six sided socket, and a bloody big hammer, the little bleeder (shute your faces) still sheared.
Anyone in the vicinity of Teesside fancy helping an OOFer out for a reasonable fee... or any recommendations?
I'll do timing belts, subframe removals, make my owm brake pipes... but if I cock up my first attempt, my lovely original Merc caliper will be scrap and I'll have to get a new one. And I'm already on first name terms with the young parts lady at Mercedes Teesside. .. (Opti would approve)
minifreek
Can you not get a tapered reverse tap into it...?
D.I.L.L.I.G.A.F...
biggriffin
Quote from: minifreek on 02 July 2016, 20:36:10
Noooo! Use a drill to drill it out then blind tap it, and can we see evidence of the hottie at Mercedes.
Hoof'land storeman.
He did say he doesn't want to make things worse!
A left hand drillbit  might be a good idea, but your best bet would be to find an engineering firm to do it for you
Migv6 le Frog Fan
Had the same with all 4 calipers on my 190. Tried drilling them out etc. but in the end, it was easier to just buy god second hand ca;ipers at £20 each.  ;)
Well, the local fuel injection specialists are currently knocking up some new steel fuel lines for the car, I'm sure they will have the kit to rescue my siezed nipple... and I will even get some photos of the pair of them* on here soon!
*the 190s, not my nipples
ronnyd
Quote from: GastronomicKleptomaniac on 03 July 2016, 14:25:02
Rather see hers
There a bit of as wine, the bleed nipple usually corrodes to the seat as well as the threads and its te seat that actually creates the seal  :y
