PFL Dash Display Removal - Help please!!
Started by Scatmancraig, 05 July 2016, 07:53:36
Scatmancraig
I need to get to the back of my dashboard radio / Trip computer display.  Some kind soul has cut the wiring for the radio loom.   Now I'm left with 4 brown/white wires coming from behind the dash, and 4 brown/white wires on the connector, but I've no idea which one needs to be joined to which.  I could just fit an aftermarket head unit that doesn't need the dash display, but that would be too easy....!
As I would like to get the dash display fully functioning, my plan is to pull the display out of the dash and work out which wire is which from the source, i.e. the display unit.  To do this, I guess I need to remove the speedo binnacle, as the radio display seems to be part of it.
So, how does the speedo binnacle unit come out of the dashboard?  I can't seem to see any screws etc. Or is there another way to work out the wiring?  Any help would be much appreciated!
frostbite
The search button is your friend  :D
Pop the centre vents out, remove the two screws (close off the vent so they dont get lost in the pipes) then lift off the vent face,
there should be a single screw left to take out. next remove the steering coloumn cowl and there should be a screw to remove.
the clocks should lift out from the left and slide, Do not have your key in the ignition
e46 325i se - 1.8vvti avensis liftback
Scatmancraig
Quote from: frostbite on 05 July 2016, 13:21:34
Useful information, thanks.  Have found an old post wwith pictures, although it sounds a lot easier that I was expecting!
Next question....
By gaining access to the back of the dash display, am I likely to find what I'm looking for?  I could really do with a diagram of the wires that lead to the dash unit..  I'm basically looking for the ones that communicate with the radio.  I don't know how many (if any) of the severed brown/white coloured wires in my car are the correct ones that feed info between the dash display and the radio???
frostbite
the only wires behind the dash go to the mfd, the speedo has its own fixed connector block
Scatmancraig
Quote from: frostbite on 05 July 2016, 14:01:31
So it should be fairly easy to find the wires, but is there anything on the back of the MFD that tells me which one is which?  Or a diagram?  I have the wiring diagram for the radio connector block....
I'm assuming its numbers 17, 18, 19 and 22 that lead to the MFD, but how do I know which is which at the MFD end, since they are all the same colour?  I need a diagram of some sort if anyone has one?
zirk
#5
MID -
Pin 7    Grey/Yellow stripe - Instrument Illumination (dimmer controled)
Pin 8    Red/Grey Stripe - Radio (aerial power feed / Radio on indication)
Pin 9    Brown/White Stripe - Radio Serial Interface
Pin10   Brown/White Stripe - Radio Serial Interface
Pin11   Brown/White Stripe - Radio Serial Interface
Pin12   Blue/red stripe - Speed signal (from ABS controller)
Pin14   Brown/White Stripe - To pin 8 of diag connector (to support programming)
Scatmancraig
Quote from: Doctor Golllum on 05 July 2016, 14:49:08
MID -
Cheers for that, but I'm not sure that it will help much.  Which of the brown/white "Radio Serial Interface" wires is which.  I presume its pins 9, 10 and 11 that need to connect to 17, 18 and 22 at the radio connector end, but which connects to which?
zirk
Quote from: Scatmancraig on 05 July 2016, 15:07:48
MID -
Cant help with that Im afriad, either someone will be along that knows, or someone can buzz them through if theve got a dash / radio hole in bits.
Shackeng
Haynes has a comprehensive wiring diagram for both pre and mid Facelift... :y
Scatmancraig
Quote from: Doctor Gollum on 05 July 2016, 16:12:15
Does anyone  have one to hand? I've managed to work out which pins on the mfd relate to which bits of wire where they've been cut, and labelled them. Just need to know which ones they relate to on the radio connector now
There's also a guide for retrofitting Mid to Tid fitted cars...
This also includes most of the pinouts ;)
zirk
Quote from: Scatmancraig on 05 July 2016, 16:41:47
Google it, there are PDF Manuals and Wiring Diagrams out there, the Wiring Diagrams will probably be in German but the Pin Out numbers should be ok.   ;)
frostbite
Just a shot in the dark,  but we're the wires cut at an angle?
Then you could just match them up, or just lable them and try each one in a different pin till it works as there's only 3 wires
