Author Topic: Dash temperature gauge not working?  (Read 2203 times)
Martin Nash
« on: 11 July 2016, 12:28:43 »
Hi All
Would anyone have a Dash temperature gauge only my gauge is not working. The sender has been replaced by my local garage but the temperature still shows the engine cold with the needle not climbing? Chalky at tha garage has told me that this is quite unusual to go wrong but this does seem to be the case!
Regards,
Martin
Re: Dash temperature gauge not working?
« Reply #1 on: 11 July 2016, 18:12:04 »
What engine, and did they replace correct temp sender (there are 2).
Place palm of hand on rev counter, and smartly, firmly press back - it dash feels like it reseated (you'll know!), try again.
Failing that, if near me, pop it round, we'll have a look.
« Reply #2 on: 11 July 2016, 22:34:29 »
Test the gauge by earthing the single blue wire from the sender ... the gauge should show fully hot
Martin Nash
« Reply #3 on: 12 July 2016, 11:36:45 »
Although the sender was replaced the garage did check the gauge in the dash with what I would assume was an amp meter and this showed that it was giving no current completely dead!! :(
Regards,
Martin
Martin Nash
« Reply #4 on: 12 July 2016, 11:39:58 »
Just for reference the Omega is 3ltr elite.
« Reply #5 on: 12 July 2016, 14:39:57 »
Regards,
Martin
Replacing the wrong sender won't have fixed it...
Martin Nash
« Reply #6 on: 12 July 2016, 21:02:55 »
Thanks Doctor Gollum
I will check that with the garage!
« Reply #7 on: 13 July 2016, 02:14:59 »
ECU Coolant Temperature Sensor...
https://goo.gl/images/wNqtng
Temperature Gauge Sender...
https://goo.gl/images/CbLN4R
Page created in 0.271 seconds with 17 queries.
