A curious question
Started by citroenguy, 14 July 2016, 11:12:05
citroenguy
A question on the same topic as the Scenic discussion a couple of weeks ago.
On many Fords and Volvos, Focus, Mondeo, c-max,s-max etc and Volvo C30/S40/V50 you have to remove the flippin throttle pedal   ??? to change the cabin air filter. Is it the same silly solution on RHD examples?
124k on the C5
I like Omegas Senators and all other big 90´s euro saloons.
Previous motors: 3x Rover 600s, Citroën ZX, Volvo 850
No although its usually a glove box out job
It's not silly at all. These cars are designed for the LHD market (i.e. the majority) and in that instance the pollen filter is under the glovebox. If people insist on driving on the left, then a steering wheel and a set of pedals have to be installed in front of it.
citroenguy
I think you got me a bit wrong stemo ;), on lhd examples you have to remove the pedal. I when I replaced one of these, I thought "this must be much easier on a uk spec V50.
124k on the C5
Quote from: citroenguy on 14 July 2016, 18:10:00
Our Renault megane had the pollen filter under the pedals on the left hand side of the car as you look at it from the front. The dealer explained that, on the continent, the glove box would be there and that is why the pollen filter was on that side.
Location of the pollen filter on SWMBO's Citroen C3 is about its only redeeming feature .... under the bonnet remove a small cover, slide one out, slide the other along and then slide it out. 60 secs max for both  :y
henryd
Quote from: Andy B on 14 July 2016, 20:29:15
Old Picasso was the same,piece of P :y
other rides
Diamond Black Geezer
Another example of why the 'stupid/impractical' executive car the the Omega is/was completely trounces new metal in the practicality stakes.
Set kettle boiling.
Lift bonnet, lift flap, plop new one in, shut bonnet
Wait for kettle to finish boiling, make cup of tea.  :)
Quote from: Diamond Black Geezer on 15 July 2016, 15:26:25
Set kettle boiling.
And, while you're in there, do the weekly clean of the breathers, egr and throttle body. Also make sure the hbv hasn't wet itself.
Cynicism? Surely not!  :D
TD
Quote from: Marks DTM Calib on 14 July 2016, 11:27:51
Ive never had to take the glove box out to change a pollen filter.....and ive changed them on every car ive had that's had aircon.
They've always been behind the glovebox, taking the sound deadening cover that's underneath the glovebox, usually held in by a couple clips has always given access to it  :)
Quote from: STEMO on 15 July 2016, 15:42:12
Set kettle boiling.
And change the passenger side spark plugs, or replace wornout plug leads. Hell, 'just' fit a new DISpack. Flush the heater matrix? Rear wheel bearing? ATF check/topup/replacement due to the lack of a dipstick?
Oooh, mean!  :D
I was astonished at a mates new C Class (P reg) and how easy everything easy laid out in the engine bay, looked like a servicing joy. 2.3 litre but so much room in the engine bay.
Quote from: Diamond Black Geezer on 03 August 2016, 09:37:00
Oooh, mean!  :D
Designed for a V8 ;)
Ahhh, it does look it, actually. Viva HC was the same (well, V4) absolutely nothing but a big space, with an engine somehwere in the middle. I swear there was more luggage space under the bonnet than in the boot!  :)
