amazon clearout
Started by annihilator, 16 July 2016, 22:03:10
annihilator
looks like amazon are having a sale on older stock car parts,just picked these up for spares
Magneti Marelli MM1199K1 Timing Belt Kit
£37.41
Quinton Hazell BFK346 Brake Shoe Fitting Kit
£5.49
VEMO Crank Sensor, flywheel V40-72-0357
£7.16
Sachs 3000951060 Clutch kit
£12.93
Nissens 63073A Radiator, engine cooling
£20.29
TRW DF2645 Front Brake Disc kit
£7.37
Mapco 15852 Rear Brake Disc, Set of 2
£8.54
Fuel Parts CU1004 Ignition Coil pack
£6.34
Magneti Marelli BSS2019 H/Brake Shoe kit
£5.54
still some bargains to be had air con. compressor £18.20
https://www.amazon.co.uk/Hella-8FK-351-102-051-Compressor/dp/B00BNYMX3E/ref=sr_1_4?s=automotive&ie=UTF8&qid=1468702848&vehicle=117-1560-1930-8118-1-0&sr=1-4&keywords=compressor   :y
John.
Mr.OmegaMan
Quote from: annihilator on 16 July 2016, 22:03:10
Good timing i'm in need of a new Compressor, Ordered  :y ...Will just have to wait and see if Amazon honour the deal.
Thanks for the heads up John  :y
Migv6 le Frog Fan
I put it in my basket and 5 minutes later it went up to  £205.55. ::)
Mr.OmegaMan
Quote from: Migv6 on 16 July 2016, 22:53:42
So it has  :o
It did say there was only one left, Now says 7 left at £205.
annihilator
No reason for them not to honour it,as they are all mostly last one in stock and not pricing errors.not just omega stuff either look on hotukdeals for more info.
John.
EMD
Thanks for the heads up . Ordered well over £200 worth of parts discounted to £43  :)
not for omega though  :-X
Omegatitis
Mr.OmegaMan
#7
Might be of use for someone with a diesel Omega, if not their selling for around £400 on eBay. https://www.amazon.co.uk/gp/aw/d/B009QXBAXS?pc_redir=T1&redirect=true&tag=ho01f-21 one available for £117
EMD
Got a bran new rad for £10  :o Then the day after its listed for £83  :o :o :o
Omegatitis
omegod
How are you finding these bargains on amazon??
Mr.OmegaMan
Received a new Bosch MAF for a 3.2 for £5 yesterday. Was taken back a little. Wouldn't even get a used one for that!
Mr.OmegaMan
Quote from: omegod on 22 July 2016, 13:47:46
One way I found was to enter what you want, Select price low to high and select delivery via prime. Most of the good stuff has gone but there's some stuff out there especially for less popular cars.
Mr.OmegaMan
Quote from: Mr.OmegaMan on 16 July 2016, 23:16:35
So it has  :o
Received the Hella A/C compressor today, Also came with new seals. Well chuffed.
That's a great deal!  :y
I had a peruse last night and spotted front shock absorbers for £7-8 each!  :y  Unfortunately both suppliers who had them at that price only had one and they were supplying different brands.  ::)
