PAS leak fixed! and thanks to DTM
Started by Webby the Bear, 21 July 2016, 19:39:21
Webby the Bear
So for far too long I've had a pas fluid leak. Mark said it was probably the hose from reservoir to top of pump. I've had the hose from Vauxhall for ages and got round to it today.
Well mark u were spot on so thanks for that. It was so brittle on the pump end it was twisting round even with the jubilee still tight!!! But obvious it's next to the fannymould so it's going to get hot even with the heat shield on.
Also ages ago I broke off the battery hold down bolt in the battery tray so the plan was to remove battery and remove battery tray and drill it out and retap the hole. I then found out the battery tray is not removable and is part of the oppsing wing! Lol so had to do it in situ. Still piece of piss and I now have the oem hold down back. And even painted it as it was a bit rough looking. All in all a nice couple of jobs ticked off!!! Feels good 👍
RIP Paul Lovejoy
Good job you did the battery retainer as it's an mot failure.  :y
Webby the Bear
That's right stemo. I've had a hideous looking generic hellfrauds one on since I snapped the bolt lol
RIP Paul Lovejoy
Webby the Bear
Totally jinxed myself with this thread. Got home last night to car smoking. Pas fluid leak totally fixed. Cam covers tho not so healthy  ;D
RIP Paul Lovejoy
