Supplier of green base instrument illumination bulbs
Started by terry paget, 21 July 2016, 23:17:31
terry paget
ON all used cars I buy, the instrument display is dim as the bulbs are either out or blackened. Vx sell them, at hot prices. Is there a cheaper supplier?
biggriffin
Hoof'land storeman.
robson
My panel showing Petrol consumption, outside temp ,etc is very dim it does change with the adjuster but certainly on a bright day I cannot read it. Is it a big job to get to the bulbs.
frostbite
Are you talking about the info display that uses 501 sidelights same as the dash. Or the warning lights on the dash that uses grain of wheat bulbs 286 t5
You can get 20 for 2.50 on the bay
e46 325i se - 1.8vvti avensis liftback
terry paget
Quote from: robson on 22 July 2016, 09:30:25
That panel is rear lit by 4 bulbs. I bet yours are as old as the car. On every used car I buy one task is to change them. It's an easy job, the whole instrument display is held in by 2 concealed screws, as described in the maintenance guide.
robson
terry paget
Quote from: robson on 23 July 2016, 10:13:29
Thanks Terry I will have a look
Just changed mine. Note the old pair here are blackened after years of use, the new pair are clear. These bulbs are on all the time the engine is running, whereas all the rear are rarely on, so these gradually dim.
Quote from: terry paget on 23 July 2016, 09:55:08
I made the mistake of doing that on one of my Capris. I don't know what I was thinking, as I always have the panel dimmer turned down(always, on everything I drive). The damn lights were so bright I had to put the original bulbs back.
Modern cars are particularly bad for me as they have so many light sources. And why do manufacturers insist on making them coloured? Pale green is OK, but bright red, or worse still, blue are especially annoying. I keep saying this, but Saab's black panel idea is something I wish had become more common.
