Wanted, AR25/35 Auto Gearbox sump pan
Started by Shackeng, 27 July 2016, 16:07:12
Shackeng
As above really. I would like a large rear sump pan off an AR25/35. Although I have a spare 25, the sump plug fitting is adrift inside the sump, and is unusable on a car. As I am about to fit the Senny AR35 which has a different sump, at present I will have to swap the one off the box coming off. It will be simpler if I can fit the correct sump before I fit it. :y
Diamond Black Geezer
The big pan with the drain/filler plug on it? Got one here, no idea how to get it to you, though (well, postage, obviously, but might be prohibitive in cost, given the weight) I'll try and get a price for you, I'll weight it tonight..  :)
Shackeng
Quote from: Diamond Black Geezer on 27 July 2016, 16:30:16
That's the kiddie, cheers DBG. :y
Quote from: Shackeng on 27 July 2016, 16:32:49
As Jimmy Saville used to say.  :y
