Wanted, 4 pin plug from auto box
Started by Shackeng, 29 July 2016, 22:36:24
Shackeng
As above, wanted is the 4 pin plug receptor shown on the left in the pic. Trying to remove one from my old box to fit into the new AR35, it broke. Annoying as I got the other one out OK.>:(
pauls
I have a wire loom from a 2.6 which has the plugs from the gear box. If they are the same you can have it. Hopefully a idea of what it looks like would help me as Al changed the loom for me so dont know what goes where.
Shackeng
Quote from: pauls on 29 July 2016, 22:50:56
I think that is what I want Paul. Is it the external loom and 2 plugs that plug into the box?
Shackeng
Quote from: BIGtime on 29 July 2016, 22:59:34
May give idea on how to remove it in one  :y
http://www.ebay.co.uk/sch/i.html?_odkw=.+Connector%2C+180C+Case+%284+Prong%29+Square&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.X.+Connector%2C++%284+Prong%29+Square.TRS0&_nkw=.+Connector%2C++%284+Prong%29+Square&_sacat=0
It shouldn't have been difficult to remove, but the long locking tang broke off when bent inwards to release it, so now nothing to lock the internal plug in place. Once I identify the exact plug, I can probably source a new one as shown.The multiplug came out OK. :y
pauls
serek
If you get stuck I have complete gear box here if you want it's FOC to good home
Shackeng
Quote from: serek on 30 July 2016, 23:02:59
Thanks very much Serek. I've got so far with this one I am going to try to make it work. I appreciate the offer though, and may well get back to you. :y :y :y
serek
Quote from: Shackeng on 31 July 2016, 10:20:14
I mean you can take gearbox a part and use parts what you need
Shackeng
Thanks Serek, unfortunately, this would require putting all the new internals in an old case, which, while an option, I would rather avoid at present. In any case I have an AR25 which I could use for that. It is a thought though, and I will keep it in mind. :y
