My 2.5 V6 CDX, year 2000 Facelift Estate
Started by Tick Tock, 31 July 2016, 10:48:42
Tick Tock
I've owned this X reg estate since 2002, and bought at a time when silver was a fashionable colour...... with the many thousands of them still around it's no wonder they don't turn heads as much as other coloured Omegas.
It's been off the road for around 5 years now, withdrawn due to engine problems and suspension wear. It was easier and cheaper to just go out and buy another Omega estate - which is what I did (and the present ebay bargain W reg has kept me going, as a workhorse with very little having been done for the initial £399 outlay).
Due to the reasonable condition of the body, and having refurbished the top end of the engine, I decided to bring the rest of it back up to a good standard underneath - as a project car more than anything. The end of August brings the tax and MOT to an end on the ebay bargain, so I shall be looking to put it in for its test sometime over the next couple of weeks. OK, at the end of the day it will always be silver, but hopefully it will keep going for another few years, and then perhaps it really will be rare!!   ;D ;D
Omega 2.5 V6 Facelift Estate.
Tick Tock
Tick Tock
steve6367
Tick Tock
The area above the backbox, behind the heat shields was a little bit grotty, so the only way to access was removal of backbox and shields.
Tick Tock
Petter
 :D Nice looking omega!
I like the silverstar color.
I got a Zafira b in that color.
Did you find much rust on the heat shield above the pot ?
This is just what I'm planing to do whit my 2,6v6 elegance.  8)
Diamond Black Geezer
Nice bit of work, nice to see. Well worth getting to these things earlier, before you start needing a welder man  :)
Tick Tock
Yeah silver was the fashion of the day, and apparently white is now the new silver, although for how long who knows? My work involves dating 19th & 20th century artefacts, and it's surprising how fashions come back into vogue..... maybe another 20 years silver could well be back in, but whether the car lasts that long is another matter!
I'm pleased with what I've done to the old girl in the last 6 months (and the car too), finding it quite therapeutic getting down under there and sorting out the grotty bits. Luckily most of what I found was just surface rust, but left another couple of years no doubt more holes would start to appear. The top heatshield nuts sheared off as soon as the spanner greeted them, and these have been replaced with new studs fitted after drilling out the boot floor. The hole in the rear side valance (side heatshield just behind wheel arch) has been treated, and the area well cleaned out and repaired using mudflap washers. The latter was a combination of dirt trapped between shield and valance, as well as moisture dripping down the inside of the rear quarter / inner wheel arch / detached sun roof drain pipes.
All shields cleaned and wire brushed, with only minimal surface rust noted. Treated them to some silver caliper paint, although ordinary Hammerite has been used by others on this forum to good effect.
Car went for MOT test 2 weeks ago and the tester said it cruised through  :) :)
Just sat waiting for the end of month now......  not just to save myself £25 for part month road tax, more the principle. Looking forward to taking it for a proper drive on Thursday  :y
It's a lot more enjoyable when it's a spare car, and you don't have to be at work in the thing the next morning, I can tell you!!!  :y
But a very tidy car, so what that it's silver and as you say, fashions wax and wane, though still expect some stick from us who own other colours, like ....Diamond Black...  ;)
migiestate
Really great looking estate looks to have been well looked after  :y. I like the silver as well  :y. I have a 2003 CDX estate 58,000 miles on it now I will be looking under the heat shield tomorrow !!. Great job you have done  :y
Tick Tock
#11
The last planned job for this year is the cambelt which I started this morning, hoping new kit would arrive. When it turns up I'll finish the job, so had a tidy up..... good job I wasn't planning on going anywhere for the rest of the week!
With the car up on the ramps, it makes it easier to work on the front of the engine at a comfortable height, and after 3 hours work - no backache  :y
Worthwhile tip  :y
Not sure about specifically for the timing, but I did find that when I was working on the front of the engine the other week (waterpump and other bits) with the air intake system out of the way, as in your image, sitting on the airbox, with one foot on the antiroll bar, one leg hanging over the nose was surprisingly comfy!  :)
Keep us updated, looking forward to seeing more progress  :)
Tick Tock
Prior to this year's flurry of activity on the CDX, I had put it in for an MOT test about 3 years ago, just after completing a top of engine rebuild. It failed on front suspension bushes and a leaking petrol tank, so was put back into store and started up / moved on a regular basis. The petrol leak turned out to be the steel pipes badly corroded on the top of the petrol tank plate. The hatch area has a tendency to retain water and moisture, and corrosion here seems to be a common problem.
Feb 2016 - we had a couple of glorious sunny weeks which spurred me into doing some work on the car, after seeing it going nowhere for over 4 years. I made a start on the front suspension and was greeted by this -
One thing leads to another..... and as much as I hadn't intended to do any bodywork, this kind of grot couldn't be ignored, so has taken me on a long slow journey, gradually making my way from the front to the back of the car.
Refurbishing the wishbones with polys & GM bushes.
New Monroe shock absorbers ready to go on.
citroenguy
124k on the C5
I like Omegas Senators and all other big 90´s euro saloons.
Previous motors: 3x Rover 600s, Citroën ZX, Volvo 850
