Author Topic: Self leveling headlights, not working.  (Read 3951 times)
noodle
« on: 04 August 2016, 19:41:01 »
Hiya,
My car failed its MOT today because the self levelling headlights were not working.
The dip beam is well below the legal requirement.
Its a 2003  2.2 Diesel CDX with Xenon lights.
I've had a rootle about in there but haven't a clue what i'm doing.
Any help\ advice would be greatly appreciated.
Thanks.
Muroman
  • Finland
  • Cars for life
    • Vectra -02
Re: Self leveling headlights, not working.
« Reply #1 on: 04 August 2016, 20:09:38 »
I think mine doesn't adjust the headlight either but I have just adjusted manually from the two manual adjusters on top of the headlamp, that way they don't ask if it works in MOT they just check that it's on right level.... So manual adjustement on top of the lamps. Two moving parts on top the lamp :D I bet you can't miss them.
-Mika
Driving: Vectra - 2002 - 2.2 "GTS" - Manual
Old: Omega - 1999 - MV6 - Automatic
Old: Omega - 1995 - MV6 - Manual
« Reply #2 on: 04 August 2016, 21:04:26 »
Check whether the reflector flaps about in the breeze, it's a common fault that the plastic beam adjuster fails, hence the lamp shining on the ground. http://www.omegaowners.com/forum/index.php?topic=90638.0
Not sure if the ally adjusters are still available though  :-\
noodle
« Reply #3 on: 04 August 2016, 21:47:08 »
Thanks Muroman & Andy B.  I'll have a look tomorrow, see if everything is intact before trying to manually adjust them.
You might be hearing from me again,,, lol.  ;D
« Reply #4 on: 04 August 2016, 23:53:37 »
That won't be a problem  :y
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
« Reply #5 on: 05 August 2016, 07:21:34 »
If both are low do you have the "FLD vision low" message on the MID?
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #6 on: 05 August 2016, 07:58:56 »
Plastic/ silicon adjusters available on eBay, think nickw bought some.
Hoof'land storeman.
Omega VT3000
  • Essex
« Reply #7 on: 05 August 2016, 08:12:56 »
I bought some resin ones recently for £8 each of the Bay of e. Haven't fitted them yet though.
biggriffin
« Reply #8 on: 05 August 2016, 09:11:19 »
That's them. :) run the threads,and bit of silicone spray before fitting.
Hoof'land storeman.
neil74
  • newport
    • 2.6 elite estate.
« Reply #9 on: 05 August 2016, 11:59:52 »
My sensor has fallen to pieces too. could I adjust the headlamps to their correct position and get away with it on the mot or do I have to have it all working properly.
Thanks
Neil.
biggriffin
« Reply #10 on: 05 August 2016, 12:55:00 »
Yes, as long as the pattern is correct,and the alignment is right.
Only problem you have is, after you set the alignment, and drive it might move. :-X
Hoof'land storeman.
« Reply #11 on: 05 August 2016, 13:08:11 »
If by 'fallen to piece's you mean that the arm has popped off, then carefully application of cable ties will serve as a half decent temporary fix  :y
« Reply #12 on: 05 August 2016, 13:16:09 »
If by 'fallen to piece's you mean that the arm has popped off, then carefully application of cable ties will serve as a half decent temporary semi-permanent fix  :y
 ::)  ;D
