WANTED - ABS ECU for 1999 2.5V6 Auto Part no. 0273004206
Started by stuvaux, 05 August 2016, 13:09:50
stuvaux
Hi,
As per title, I require an ABS ECU for a Mini-facelift 1999 2.5 V6 Automatic. It is Bosch part number 0273004206
Thanks in advance
Take a look at my Dog Training blog at Dog Training HQ
Diamond Black Geezer
If it helps, all you need is the same sort of car, so MFL, or FL, doesn't matter, saloon or estate, doesn't matter. So long as it's a 2.5 V6 and an auto (and MFL onwards, not PFL), it will be a direct fit. You can compare the two-letter code to be super-sure.
stuvaux
Quote from: Diamond Black Geezer on 05 August 2016, 13:17:41
Great, thanks for the info. Mine is currently with BBA Reman, I am expecting it back on Monday so can check other codes then. They couldn't repair mine as they said it wasn't "communicating"
I saw the thread, yes... sad indeed. I'm looking for a spare myself (but far scarcer, as mines a 'full' PFL, not a MFL like yours, thanks to the different Traction Control system)
stuvaux
Quote from: Diamond Black Geezer on 05 August 2016, 13:47:05
Good luck with that. I am hoping to get one soon as I am going to Ireland at the end of the month.....would rather it was fixed for then!
But they don't communicate when the standard fault arises .......as its some of the power supply bond wires that come adrift.
stuvaux
stuvaux
Quote from: Marks DTM Calib on 05 August 2016, 15:59:57
That's what I thought but they told me it wasn't fixable and tried to sell me a new one for £400
stuvaux
I have been offered one from a facelift X30xe auto with the same Bosch part number. Is this likely to be okay?
Quote from: stuvaux on 05 August 2016, 17:19:20
Ident code is the determining factor ;)
stuvaux
Quote from: Doctor Gollum on 05 August 2016, 17:30:30
Which code is that? I only have the Bosch one as the unit is currently with BBA Reman
minifreek
You have PM and I got the ABS ECU off for you :)
Car was supposed to go before 6 but hey haven't turned up as yet, but didn't stop me from having a frantic 15 minutes of spanner twiddling LOL
D.I.L.L.I.G.A.F...
stuvaux
Quote from: minifreek on 05 August 2016, 18:09:54
Much appreciated. That's quick work  :y
minifreek
D.I.L.L.I.G.A.F...
