Springs.
Started by ted_one, 10 August 2016, 08:34:40
ted_one
Sorry about the disjointed effort to load pictures,Photobucket is really slow...so have given up,just thought you'd needed the heads up on this product :)
Diamond Black Geezer
That's shocking, considering that's worse than my MV6 springs of some 15-odd years vintage  :o
This isn't going to help, but I've found it interesting for ages:
Spring failure is common on lots of recent cars. The main culprits(Mk6 Fiesta, C3, Laguna, Mondeo) can usually be diagnosed over the phone, but the majority of the ones I saw were on low-mileage/usage cars. That is something that I don't have a good explanation for.
ted_one
Really strange, that in all my 15 years of Omega ownership I have had only one spring failure and that was on a car that I had owned for 12 years.Perhaps there might be something in what Nick says :-\
the alarming man
I must admit I had 3 go on  that rubbish Vectra I had  >:(
I had a bad experience with KYB, they snapped very early on. But Boge ones fitted now in both mine are lasting very well, must be 5 years now, no signs of serious corrosion either.
Quote from: tunnie on 15 August 2016, 09:45:20
Both the rear KYB's where snapped on a car a picked up earlier in the year, looking at it you would never know as they both snapped in the same place (pigtail) so the car sat level! Swapped the lot over from my written off 2.6 so it sits on MV6 and Bilstein B4's now.
ted_one
Going to keep a close eye on these Pedders springs,can't do much about that as they have been fitted,but also on the tear down Serek found that one of the Pedders top mount bushes was on borrowed time, although the other one had been changed...it seems that Pedders quality is looking a bit iffy ::)
biggriffin
If they are poly and have torn, that's because there's no give, and the bush is the weakest link, could be why springs have gone, (it's too stiff,  :o oo Er missus), might need to check turrets next time it's a sereks.
Hoof'land storeman.
humbucker
I ad an OE spring snap on my Elite a few years back. Not cool.
http://www.irmschermv6.com | #irmscherMV6
PM with your requests.
Believe my missus' parents' Fiesta  has been through 6 springs in about 5 years.
Quote from: Diamond Black Geezer on 19 August 2016, 09:38:38
Is it a mk6 that doesn't get used much? That was the most common example of broken springs I saw, closely followed by Citroen C3s, and then Lagunas when they were still a common car.
The bigger Fords do break springs, but with less obvious symptoms - the broken end is less likely to rub through the tyre and it's only noticed when the car is jacked up for other work.
I think it is Mk 6, yes. All rear, I think, And a mate at work's front spring went, and as you probably well know, the spring fliest past the strut, and jabs in the tyre. Much burning rubber smoke occurred before he pulls into work with a half-inch deep groove in the tyrewall! Silly sod! He thought the exhaust was broken!
Quote from: humbucker on 19 August 2016, 09:36:27
Original Elite SL springs are notorious for snapping the pigtails off.
Quote from: Diamond Black Geezer on 19 August 2016, 10:02:15
Fronts are much more common on Fiestas.
