2.2 dti primer bulb
Started by Magwheels, 14 August 2016, 15:28:19
Magwheels
Hi, I want to fit a diesel primer bulb to my old bus. Looking on past posts it would look like I need one for a 10mm id pipe (pipe on car appears around 12mm o.d.) and I would be looking to put it at the front of the motor on the return to the tank (top pipe).
Does this appear to be correct.
Looking at one of these.
http://www.ebay.co.uk/itm/New-10mm-Fuel-Primer-Bulb-Hand-Pump-Diesel-Petrol-Gas-Priming-For-Vehicle-Car-UK-/272279983272?hash=item3f6526d4a8:g:ba4AAOSwc1FXZ7yU
Any thoughts or input much appreciated.
raywilb
Quote from: Magwheels on 14 August 2016, 15:28:19
I actually bought exact last week  & it was delivered promptly. buy one is my advice  they are good. they fit tightly & with having metal nipples clips will tighten. ( though probably tight enough without )  :y
Magwheels
Well changed the fuel filter and the leak off pipes, added the primer bulb to help bleed the lines and hey presto the bulb leaks like you would not believe around the bulb outlets, not from the pipe but from the bulb to the spigots!! Would have accepted it if it was a cheap Chinese one but this was from Halfrauds and a Laser one. Appears there is a bit of pressure in the return line that the bulb does not like. Luckily had a 10mm straight connector that even when just pushed in without clips doesn't leak a drop. Boy what a nasty car to bleed, still all good now.
raywilb
Quote from: Magwheels on 17 August 2016, 22:20:03
the one that you considered getting off the net beats those laser efforts hands down
