led load resistors
Started by Andy B, 14 August 2016, 23:19:09
My 'new' caravan has led front & side marker lights. My problem with them is that they flash continuously whether the car's lights are on or off. So it's been suggested to me that it's the car's CANbus lamp check & I need to fit  load resistor across them.
My question is ....... what value of resistor am I fitting? Looking on eBay there are loads of 6ohm clicky bu they seem to be for a bigger indicator, whereas I have just 3 little leds - 1 front & 2 side marker each side.
Any suggestion of a resistor size would be most welcome
TIA
Bigron
Andy, whilst you were on eBay, did you not look at CANbus LEDs that are a direct replacement for your existing lamps? Not knowing exactly what type of ;amp you are currently using, I can't give you a ;ink, sorry.
Ron.
Quote from: Bigron on 15 August 2016, 00:21:45
Ron.
The led is integral to the fitting
biggriffin
There's posh, pikey house's, now have led lights, to offset there carbon footprints, for when they use red diesel. ;D
Hoof'land storeman.
Quote from: biggriffin on 15 August 2016, 07:37:12
One manufacturer went the whole hog with led tail lights but it seems they caused that many problems with different nake towcars they've gone back to normal filament bulbs
Are these markers on the same circuit as the tail lights and number plate lights and are the latter also LEDs or incandescent?
I'm just thinking that, if you already have a few incandescent lamps on the circuit, it will have plenty of resistive load, and adding more may not help.
My guess is that the driver circuit pulses the lamps for a sufficiently short duration that incandescent bulbs don't start to light, but the LEDs give instant light output, so it's noticeable. More load on the circuit probably won't change that.
Where you need to add load resistors to LED lights is in indicator circuits, where the flasher unit is sensitive to the current drawn and will flash fast if too little current is drawn from the circuit.
But.. to answer your question, a 6 ohm resistor will dissipate about 24 watts when driven from a 12V supply, so it's a similar load to a single 21W brake / indicator lamp.
I suppose, if you had 5 watt bulbs in your marker lamps, they'd add up to something around that figure so a single resistor that size would be worth a try. I just have some reservations as to whether it will help. :-\
I've not looked properly yet. All the rear/tail light are conventional filament bulbs, but the front and side marker lights are led built into the reflector. I'm hoping the are wired up separately from the rear lights that I can try a resistor across them. The pulse is just an opinion from someone else that suggests it's coming from the car's light check
henryd
Quote from: Andy B on 15 August 2016, 11:25:07
Is the car towing wiring via a 7 way bypass relay or are you on the new style combined set up ???
other rides
Quote from: henryd on 15 August 2016, 23:51:45
I didn't wire it up  :-\ It looks like a dedicated loom, but was originally only a 12N, a local towbar place swapped it for a 13 pin
Both plugs have separate terminals for left and right tail lights, so I'd first check what's wired to each. If they are correctly wired to their respective tail lights and they are incandescent bulbs, then I'm not sure it's going to help, but, if you find the tail lights are on one feed and the LEDs on the other, then loading that latter feed a little more may help.
Quote from: Kevin Wood on 16 August 2016, 08:36:25....
That's what I'm hoping to find ...... I've had to go to work  :( so not been able to look
Give Sargents a ring and have a chat .. they are without doubt the best when it comes top sorting car/caravan incompatibility .. they even make plug in boxes to sort out the problems !!
https://sargentltd.co.uk/
don't know if your new van is a swift or not .. but they specalise in these ..
https://sargentltd.co.uk/shop/product/led-road-light-electronic-control-unit/240
Quote from: Entwood on 16 August 2016, 12:49:52
Give Sargents a ring and have a chat .. they are without doubt the best when it comes top sorting car/caravan incompatibility .. they even make plug in boxes to sort out the problems !! ...
Actually ... they already have the alarm from my caravan, a fault it seems with the tilt sensor part  :-\ so I emailed them my question last night.  :y :y
zirk
Quote from: Andy B on 14 August 2016, 23:19:09
TIA
Doesn't make sense that they are flashing on there own without any car lights / indicators on, which may indicate an issue or miss mash in the tow bar connector(s)?
Being leds, would they have there own flasher circuit built in?, and are wrongly being fed by voltage somehow, not convinced fitting additional resistive loads is going to help, tending more towards check the wiring first.  :-\
Quote from: zirk on 16 August 2016, 19:50:39
Doesn't make sense that they are flashing on there own without any car lights / indicators on, [/quote]
hence my question  ;) These marker lights are just that, nothing to do with indicators
Quote from: zirk on 16 August 2016, 19:50:39which may indicate an issue or miss mash in the tow bar connector(s)?
All was well with the caravan lights of my previous caravan with the same tow car  :-\ and I have checked for loose connections etc & water ingress of the both plug & socket. And as said, the filament bulbs at the back are working as the should.
Quote from: zirk on 16 August 2016, 19:50:39Being leds, would they have there own flasher circuit built in?, and are wrongly being fed by voltage somehow, not convinced fitting additional resistive loads is going to help, tending more towards check the wiring first.  :-\
I also have a Smart Fortwo that the previous owner has fitted a led festoon bulb to the interior light. Even when switched to come with the doors open, it's never quite off when the doors are shut.  :-\ They're peculiar things these leds
The Merc's light check is different from the Omega's. On the Omega, you had to turn your lights on for it to check them, same with the brake lights, the Merc though can tell you as you turn the ignition on. I understand it's done via CANbus, but as that is way beyond the scope of a simple fitter, I've no idea how it does it.  ;)
