wanted
Started by para1, 17 August 2016, 10:22:47
para1
  WANTED    AUTOMATIC GEAR OIL SUMP   OMEGA 2000  >> 2Ltr    16 vavle   B Class
biggriffin
Make it a proper wanted advert, post it in the test section, and ask admin to move into the wanted section,  am guessing its an AR25.
Hoof'land storeman.
para1
Quote from: para1 on 17 August 2016, 10:22:47
IS THERE A DIP STICK OR  TRANSMISSION OIL TOP UP  ACCESS ON THIS MODEL
Diamond Black Geezer
I think a 'Thankyou' to biggriffin for his help might be forum etiquette. Also (as is the forum guidelines) try knocking caps lock off, otherwise it appears you are SHOUTING!
The answer to your questions is 'no' and 'yes' in that order.
para1
ThAnKs  (  Big GrIfFin)    No ExCusE    SiNcErLeY
Quote from: para1 on 21 August 2016, 08:51:16
Consultation with a proctologist maybe ::)
