Cheap 'stat if anyone wishes?
Started by Diamond Black Geezer, 18 August 2016, 10:37:36
Got mine a while ago genuine GM, with the transfer pipe etc... anyone fancy it, there's a 'old stock clearance' one on the heebay... I beleive you can simply pop your old 'stat out of the housing and insert the new one.  :)
http://www.ebay.co.uk/itm/TO-CLEAR-NEW-COOLANT-THERMOSTAT-KIT-GTS900K-/391534205164?fits=Car+Make%3AVauxhall%7CModel%3AOmega&hash=item5b2941d8ec:g:5NAAAOSwV0RXsrwm
Quote from: Diamond Black Geezer on 18 August 2016, 10:37:36
You believe wrong...
The casings and stat details vary from manufacturer to manufacturer... you might get lucky, but then you might not :-\
Caveat emptor ;)
Got mine a while ago genuine GM, with the transfer pipe etc... anyone fancy it, there's a 'old stock clearance' one on the heebay... I believe you can simply pop your old 'stat out of the housing and insert the new one.  :)
If you didn't damage the housing getting it out of the Vee and off the transfer tube, or it wasn't badly corroded to start with. Considering that you can buy the whole thing for a tenner, or the OE one for £17 It's not enough of a saving for me. No, I don't insist on spending extra for a Vauxhall box to throw away, or have any problems adjusting the fit with different bolts/washers.
Ahhh, fair dos.... someone said as much on here once. Apologies for any misleadings....  :y
