Author Topic: Tyre fitters  (Read 7218 times)
Re: Tyre fitters
« Reply #15 on: 24 August 2016, 13:12:29 »
Re: Tyre fitters
« Reply #16 on: 24 August 2016, 13:40:51 »
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
Re: Tyre fitters
« Reply #17 on: 24 August 2016, 17:43:11 »
Nice well thats cleared up. Ill let him know
e46 325i se - 1.8vvti avensis liftback
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Tyre fitters
« Reply #18 on: 24 August 2016, 19:55:46 »
If u came to mine for tires you'll get them fitted with wherever the red/yellow dots end up. Complain and you'll be shown the door  😂😂😂
Joking aside my understanding was that you put the yellow dot closest to the valve as the optimum point to balance them. But in reality it doesn't matter. You balance them and as long as they balance at the end of it all' swell.
Normally I find the cheap Chinese tyres are the worst and usually take the most weight to balance.
RIP Paul Lovejoy
X30XE
  • UK
    • 740i,728i,S320 & Disco
Re: Tyre fitters
« Reply #19 on: 24 August 2016, 20:08:29 »
Not if the inside of my alloy looks like a frigging tobelerone it isn't sonny!  >:(  ;D
Omegatitis : [in remission]
Webby the Bear
  • Northampton
Re: Tyre fitters
« Reply #20 on: 24 August 2016, 20:25:19 »
See paragraph 1, sentence 2  ::)😂😂😂😂
RIP Paul Lovejoy
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Tyre fitters
« Reply #21 on: 24 August 2016, 20:53:21 »
Not if the inside of my alloy looks like a frigging toblerone it isn't sonny!  >:( ;D
Blame has already been assigned to the tyre or the fitter, but there is a third party that often causes massive imbalance that is the car owner's fault more than anything else: due to various factors, lots of modern wheels are badly buckled.
Re: Tyre fitters
« Reply #22 on: 24 August 2016, 21:40:02 »
but if the wheel having the tyre replaced came into the tyre bay with minimum weights and then needs a bucket full, shouldn't that ring alarm bells for the fitter/fitter-ess?  :-\  ;)
It also amazed me that she was so surprised when it made a huge difference by moving tyre & rim relative to each other.
« Last Edit: 24 August 2016, 21:42:38 by Andy B »
Re: Tyre fitters
« Reply #23 on: 24 August 2016, 21:41:00 »
If u came to mine for tires you'll get ..
What do we keep telling you about watching American sh1te?  ::) ::)
Webby the Bear
  • Northampton
Re: Tyre fitters
« Reply #24 on: 25 August 2016, 07:33:08 »
Based on what I've seen I'd say no. Example.....
I put some cheap shite tyres on my omega. When I balanced them they needed a shocking 120g on the outer and 90 (iirc) on the inner. I was shocked.
This tyre then kept going down so after checking for nails I took it off, sealed it with a bit of tyre jizz and put it back on in a different location. Each side took around 40g to balance.
RIP Paul Lovejoy
Webby the Bear
  • Northampton
Re: Tyre fitters
« Reply #25 on: 25 August 2016, 07:34:37 »
And sorry Andy but forgive my ignorance. What do you mean when u say about moving tyre and rim relative to each other?
RIP Paul Lovejoy
citroenguy
  • Sweden
    • 2005 Citroën C5 2.0SX
Re: Tyre fitters
« Reply #26 on: 25 August 2016, 08:12:45 »
Did you really put 120/90g on the rim?? ???
That's when I would have done as Andy says. Loosening the wheel from the rim and turning it 1/4 or 1/2 a turn. Also I always fit one of the weights and re spin it, a lot of the time it gives a different result then.
124k on the C5
I like Omegas Senators and all other big 90´s euro saloons.
Previous motors: 3x Rover 600s, Citroën ZX, Volvo 850
Webby the Bear
  • Northampton
Re: Tyre fitters
« Reply #27 on: 25 August 2016, 12:25:46 »
Yup 👍
I did mess around with it, moved it around etc but still took that much weight to balance.
As said, remounted tyre later (few weeks) and it took an acceptable amount 👍
RIP Paul Lovejoy
