Author Topic: Tyre fitters  (Read 7217 times)
Tyre fitters
« on: 23 August 2016, 22:05:05 »
At great expense, I had 2 tyres fitted to my Merc today. SHE  :o fitted one of the new tyres, placed it on the balancer, spun it up & it told her to fit a 45g & a 30g weight. She then spun it up again and proceeded to fit another packet of them elsewhere on the rim. I intervened & said I wasn't happy with the amount of weights she was going to be fitting. She looked at me blank.  ??? I suggested she moved the rim & tyre relative to each other. She looked at me blank.  ???
She sought help and re-balanced it .... I've not actually looked yet, but when she was fitting the wheel to my car, she said .... I didn't know you could do that!  ??? ???
Re: Tyre fitters
« Reply #1 on: 23 August 2016, 22:14:59 »
Tyre fitters like to drive customers cars on and off the ramps. What would you have said if she'd jumped behind the wheel?  ;D
Re: Tyre fitters
« Reply #2 on: 23 August 2016, 22:17:46 »
You need a jack or two to remove wheels ..... not a ramp  ;)
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Tyre fitters
« Reply #3 on: 23 August 2016, 22:41:55 »
If they use a two-post ramp, the "free safety inspection for your peace of mind" is easier. And so is up selling new shocks, an exhaust, the other two tyres, solid gold wiper blades and a baby seat. Not that any fast fit centre would actually do that.
Re: Tyre fitters
« Reply #4 on: 23 August 2016, 22:50:47 »
My local place uses a ramp, I'd say that was another minus for yours.
Re: Tyre fitters
« Reply #5 on: 23 August 2016, 23:02:38 »
I don't use fast fit centres unless really really stuck. This is an independant tyre bay, been going there years, unfortunately she seems to have a training issue  ;) ;)
the other two tyres were fitted by them last year sometime  :y ............. at £200 each, they only get repalced as pairs, 4x4 or not  ;) ;)
Re: Tyre fitters
« Reply #6 on: 23 August 2016, 23:04:14 »
they have just 2 four posters, one in the tyre bay & t'other in the MOT bit behind and where they have a 'tracking'/geometry set up
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
Re: Tyre fitters
« Reply #7 on: 24 August 2016, 07:59:15 »
Here a question that should come under the title
What is the red spot and yellow circle for on the tire wall
e46 325i se - 1.8vvti avensis liftback
Re: Tyre fitters
« Reply #8 on: 24 August 2016, 08:02:55 »
Point of maximum run-out and point of maximum imbalance, IIRC.
frostbite
    • 00' e46 325i se
Re: Tyre fitters
« Reply #9 on: 24 August 2016, 08:05:12 »
Ok well that clears it a tad. My welder friend thinks its where the valve is suppost to be positioned  :o
Re: Tyre fitters
« Reply #10 on: 24 August 2016, 08:27:17 »
He's kind of right ..... that's the starting point
citroenguy
  • Sweden
    • 2005 Citroën C5 2.0SX
Re: Tyre fitters
« Reply #11 on: 24 August 2016, 08:37:32 »
Not all tyres come with the dots. I would say that 45g is a tad high but still normal. its worse when the balancer tells you to fit 70g and 50g.. :D (usually cheap tyres)
124k on the C5
I like Omegas Senators and all other big 90´s euro saloons.
Previous motors: 3x Rover 600s, Citroën ZX, Volvo 850
Re: Tyre fitters
« Reply #12 on: 24 August 2016, 08:48:59 »
Yeah - I can't remember if the dots are "at" the position of greatest run-out & weight or if they are opposite (and therefore the idea is you line the valve up with one rather than put the valve opposite one).
Ever noticed the red & yellow lines around a tyre? They mean something, too.. I forget what, though  :-\
Re: Tyre fitters
« Reply #13 on: 24 August 2016, 13:00:20 »
If she'd just fitted the 45g & 30g weights I'd have left it at that, but when she spun it and wanted to add another handful, that's when I said I wasn't prepared to have it balanced like that.
They are Michelin Latitude Sport 3 ......
Re: Tyre fitters
« Reply #14 on: 24 August 2016, 13:02:22 »
Like you, I know they're to do with the heaviest/lightest part of the tyre lining up with the valve which is the heaviest/lightest part of the rim ...... but can never remember which ...... I think it's an age thing  :-\  ;D
