seat problem
Started by pauls, 24 August 2016, 14:16:20
pauls
I have just replaced my elite drivers seat with a mv6 seat. I now have a couple of problems. Help needed please.
1. On replacing the seat i found that i now have a spare yellow wire. I plugged in the yellow wire with the yellow plug. I now have a yellow wire with a grey plug spare.(coming from car loom)
2. My airbag light has come on. Keys no where near car until wires connected.
3. I also have a big grey plug coming from the loom that wont plug into anything on the seat.
4. Took the car for a quick spin it feals like the heated seats are on. On turned on by dashboard. Is they a fuse i can pull.
5. Seat to high i know you can use a socket but cant remember i think 13mm but my halfords one wont go up the hole
Diamond Black Geezer
Really beyond me, I've only ever swapped like-for-like, but I have a slightly sickly feeling you need a Tech2 to get that airbag light turned off...  :-\
Both seats have airbags, and they're definitely connected? If that's the case, there's really no reason the car 'knows' there's a different seat in there  ???
pauls
Just had a look on here and it looks like i cant pull a fuse for heated seats as fuse covers other things. Could i just unplug the heater side from the seat.
Do you still have the old seats? Need to see what's what... issue/solution should then present itself :-\
Biggest problem I have is that I only have two free days in the next fortnight :'(
pauls
Still have old seat here...i have the seat in a decent position could i not just unplug the seat i know the airbag wont work but it will stop me getting a hot arse.
pauls
Sorted no 5 seat height now working
Quote from: pauls on 24 August 2016, 17:08:32
If it's non Elite seats, then height does tend to stick. Rocking the switch usually does the trick
QuoteI plugged in the yellow wire with the yellow plug.
QuoteMy airbag light has come on.
Reason being is that your passenger seat must have had a CSS (child seat sensor)
Quotethere's really no reason the car 'knows' there's a different seat in there
It does if the seats are not "like for like" regarding the fitment of a CSS in the passenger seat ;)
pauls
Just to say only changed the drivers seat. Not to worried about airbag. My main concern is the heated seat coming on without me touching the dash control
Quote from: pauls on 24 August 2016, 17:19:02
I would be. With that light on, the entire SRS system is disabled
pauls
Thanks rob, Didnt know that.
pauls
Sorry cant get these things to show, but if somebody can you will see whats not connected and what is. can i unplug one of these to turn off the heated seat.
ted_one
Best thing you can do Paul is,put the Elite seats back in your car and give me the MV6 seats.....save you the arse ache :)
pauls
Quick update ..managed to figure out which plug does the seat heater and is now unplugged :y
Incase anybody is interested it was the black plug with the black rubber cable covering
Next thing is to figure out why my airbag light came on >:(
