2.6 V6 estate breaking
Started by omegod, 27 August 2016, 17:21:17
omegod
Making it's last journey to Omegod towers sometime tonight is a nice manual 2.6 estate in Jewish racing gold, header tank , mirrors, door strips, front bumper , gearbox + prop already spoken for but the rest is available so please form an orderly queue ;D.
To start ,Front locking solenoids 20 quid each posted
omegod
This is Z489
Doors are mint and completely rust free are 35 each and I can swap them here if someone wanted a drive through service
Bonnet is mint and 30
Drivers wing is mint and 20
The interior is the cleanest, unmarked CDX one I have seen and would be great to replace a tired or lower spec one
Migv6 le Frog Fan
Climate panel with no wear on the buttons ?
omegod
Migv6 le Frog Fan
Replied. Consider it sold.  :y
omegod
Coil packs in good working order £20 per side
Straight pair of rocker covers,appear to be original factory seals so no overtightening £30
MAF £18
Locking Solenoids £20 each
ECU, CL ecu +2 chipped keys £50
Alternator £20 + post
Big Rod
I'm in the market for a rear xenon leveling sensor if it's got a good one on it. :)
If I have to explain you won't understand!
If the diff is the same as the 3.2 one and is in known good order I might be very interested ...
Quote from: Entwood on 04 September 2016, 17:14:57
2.6 manual diff should be same ratio as 3.2 auto iirc :y
PM sent regarding drive shafts .. :)
frostbite
Just out of interest, what would you do the engine and ancilleries for an easy swap?
e46 325i se - 1.8vvti avensis liftback
omegod
MAF £18
ECU, CL ecu +2 chipped keys £50 sold
Good passenger side xenon £20 + post
Nice drivers window switch £15 posted
Nice headlight switch £15 posted
Still plenty on this if anyone wants any bit's
biggriffin
Received the stereo, all fitted n working, was in safe mode, but sorted. As described  :)
Hoof'land storeman.
Migv6 le Frog Fan
Received climate panel a week ago, but forgot to say so at the time.  :-[
Not fitted it yet.
powerslinky
