Author Topic: Pool of water  (Read 2346 times)
Chief972
  • South Yorkshire
    • Omega 2.2dti Y Reg
Pool of water
« on: 04 September 2016, 19:18:54 »
Hi I noticed a pool of water under the passenger side front today and managed to trace it to a pool of water a few inches deep just under the pollen filter housing, my coolant is fine I think maybe it will be rain water is this correct or am I missing something. Thanks.
gbh
  • forest of dean
    • omega cdx 2.6
Re: Pool of water
« Reply #1 on: 04 September 2016, 19:21:08 »
There is a drain there which sounds like it might be blocked!!!
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Pool of water
« Reply #2 on: 04 September 2016, 19:40:36 »
Did you have the A/C on?
Re: Pool of water
« Reply #3 on: 04 September 2016, 19:51:11 »
Deffo blocked drain, work back along the chassis rail until you reach the bottom of the bulkhead. Drain is just above...  :y
Re: Pool of water
« Reply #4 on: 04 September 2016, 23:46:37 »
As above, the drain is blocked. Roll up your sleeve &  get your arm in there & have a poke about ( ::)) ... your arm wil go in there ... just a little more difficult getting it out.
http://www.omegaowners.com/forum/index.php?topic=90582.0
http://www.omegaowners.com/forum/index.php?topic=90535.0
« Last Edit: 04 September 2016, 23:48:55 by Andy B »
Magwheels
    • 2.2 dti Elite saloon
Re: Pool of water
« Reply #5 on: 06 September 2016, 18:34:31 »
Give it a poke with a bamboo cane then the pressure of the water should help clear it.
