Author Topic: Pending Fault codes P0560 and P1781, anything to worry about ?  (Read 2487 times)
DrAndyB
  • The Wirral / Cheshire
    • 2.5 V6 CDX Manual (MFL)
Hi all,
I finished the work on my Dad's 2.2 Petrol FL Auto, new GM rocker cover gasket all good  :y
I borrowed a code reader and there were 2 codes stored under Pending.
P0560, which I believe is voltage which I can understand as he did charge battery as was low.
The other code is P1781 - not 100% what this is, but intel suggests Torque Signal ?  Is this something to worry about ?, Especially as a few things got unplugged when did his Rocker cover and gave old throttle body.
Thanks again.
Andy.
Re: Pending Fault codes P0560 and P1781, anything to worry about ?
« Reply #1 on: 10 September 2016, 09:28:09 »
Memory tells me that often gets thrown up if the Cam sensor is misbehaving on a 2.2.
Any hot starting hessitation at all?
DrAndyB
« Reply #2 on: 10 September 2016, 22:42:59 »
Thanks for the post.  She seems to be running sweet, no hot starting problems.  Starts from cold ok after throttle body and breather clean, but I only did that 12 months ago so was pretty clean.
He did have a battery issue which I think caused limp home mode as Diode pack failed.  Hopefully it's a remnant of that with the other voltage code.
I have reset all codes and will see how it goes.  Had a run in it today with him, so i may plug code reader in again to check for him tomorrow before I go.
If is cam sensor, are they simple to change on the 2.2 ? And I assume GM flavour ones preferable.
Cheers,
Andy.
« Reply #3 on: 11 September 2016, 07:29:27 »
Easy enough to do, cabletray/coilpack cover/cambelt cover off, then only one bolt holding it in... lift out from top... would have been even easier with cam cover off, as it's just there ::)
And yes, genuine sensor purchased from a genuine Vx dealer that you genuinely had to walk in to ;)
« Reply #4 on: 11 September 2016, 10:19:31 »
For the P17xx, check TCM and ABS.
DrAndyB
« Reply #5 on: 11 September 2016, 18:48:20 »
Genuine advice  ;D
Will see how my dad gets on with the car - fingers crossed all is now well, and good for another 80k mls with its nice new genuine GM rocker cover gasket  ;D - thanks again to the OFF for guide and advice  :y
