This Week in Wheeler's Workshop
Started by Nick W, 10 September 2016, 19:42:03
Quote from: STEMO on 16 November 2017, 12:34:10
Front wheel drive was once unthinkable with anything more than 250bhp, but there are quite a few cars which seem to go in a straight line with it nowadays.
Yep, mostly when you're trying to negotiate a bend. ;)
Only by using different length suspension components and  individual wheel braking to counter yaw ::)
Quote from: Doctor Gollum on 16 November 2017, 12:39:28
To counter my what?  :-\
Technically I'd say that any decent car suspension should have different length components - specifically the upper & lower wishbones; anything else is a packaging or financial compromise that results in sub-par handling ;)
Quote from: Kevin Wood on 16 November 2017, 12:38:32
As a kid I had a Corgi model of the Oldsmobile Toronado from the mid sixties. A nice big 7 litre V8 driven through the front wheels. :y
Great looking car. :y
Quote from: Field Marshal Dr. Opti on 16 November 2017, 13:36:00
Cadillac used the same gearbox with an 8.2l engine bolted to it. 400 lb/ft of torque from about 1000rpm.
Quote from: STEMO on 16 November 2017, 12:59:24
The effect of torque steer on the rear axle ;)
Quote from: Nick W on 16 November 2017, 14:21:33
All it needed was Frank Cannon.....or was that a Lincoln Continental?
Quote from: henryd on 16 November 2017, 11:55:48
Quote from: Nick W on 16 November 2017, 10:03:05
Power isn't a problem, as it has the 1.8VVC engine. And all of the GTI suspension parts that are necessary for such conversions.
It must bloody tramp on with that motor in it :o :y
You might think that; I couldn't possibly comment ::)
Quote from: Doctor Gollum on 16 November 2017, 11:14:07
Quote from: Field Marshal Dr. Opti on 16 November 2017, 10:59:56
Quote from: STEMO on 15 November 2017, 20:46:51
I can't see your pictures, Nick, who are you using to host them?
I'll help you out.
Nick has posted a picture of a beautiful blue Lamborghini. :)
Well... They weigh about the same :D
Metros are just over 800kg(not much more than a 'lightweight' Elise)
What Lamborghini gets even close to that?
Quote from: Nick W on 16 November 2017, 17:52:52
Most will be within about 1000kg of that. Just. ;D ;D ;D
Quote from: aaronjb on 17 November 2017, 09:28:42
Especially the full fat Vorsprung durch essen versions  ;D
The Urraco P250 tips the scale at a mere 1,100 kgs which isn't bad considering that it's twice the size of the Metro :o
Yup, sure I remember my friend with the Gallardo saying it's ~1800kg.
Doesn't feel it, mind, when you're driving it!
Made a start on the Metro.
This is NOT how to repair a rusty sill:
Especially as there's another rusty part near the front.
This is what is actually required after cutting out and repairing the grot in the floor:
A bit of tidying up, £45 and some clamps:
And run out of gas just when it's tacked on at the top, and plug welded along most of the bottom:
So I ground down the welds that I did manage to do, put the car back on its wheels(it's in the street) and went to the pub. I bought it with the arch repair panel fitted like that; I would have fitted considerably less of it so as not to need so much filler to cover the distortion.
I'll get some more gas in the week so I can finish this repair and make a start on the other side which hopefully doesn't need any work to the floor.
