This Week in Wheeler's Workshop
Started by Nick W, 10 September 2016, 19:42:03
dave the builder
Very interesting  :)
so have you considered instrumentation ? omega clocks  :-\ or will there be some complex wiring to work out to use MG dash or again an aftermarket solution ?
Nice! What is going on with that crossmember, though? It looks like it's been attacked by the bottom pulley (not that engine, obviously)..
Quote from: dave the builder on 08 April 2019, 07:49:43
Very interesting  :)
Omega clocks?? No room for them, don't have them, too much hassle trying to get them to work, as the only bit that works off the ECU loom is the rev counter. MGB wiring is very simple, with a cable driven speedo, 4 cylinder rev counter and a capillary oil pressure gauge.
And the Omega speedo is driven off the ABS sensors, not the gearbox.
So we're going to use aftermarket to make it easy: RALLYDESIGN That gets around all of the issues of mismatched sensors to the gauges, keeps all the gauge faces looking the same(a mix of cheap used gauges looks shit) and gets everything working quickly. Not expensive either.
The crossmember notch was necessary for the pulley, but Ian did insist on doing the welding with a 90amp gasless Mig. A coat of paint and the air intake over the top will deal with the aesthetics
I'll install the pickup for the speedo into the prop to gearbox adapter.
dave the builder
As the omega  OBD2 port is part of the fusebox, did you get the loom between the OBD2 and engine ecu  or is that another problem   :-\
sorry for the questions , just genuinely interested  :-[
Quote from: dave the builder on 08 April 2019, 18:44:35
I'll look, but I think it's part of one of the connectors. The port is attached to the fusebox, I don't think it's part of it. I don't have an Omega to check.  I know Ian's had it all powered up, with blink codes, so that's not difficult.
You're talking about running the odd wire from the ecu plug to the dash, hardly groundbreaking, but being able to read a wiring diagram helps :y
The Omega is pretty simple from an electrickery point of view  :y
Quote from: Doctor Gollum on 08 April 2019, 18:55:16
Only two we care about are the rev counter and water temp. Both are easy, and we probably wouldn't bother with the rev counter if the dash didn't already have a hole for it.
The awkward bits of the job will be making the exhaust manifolds and sorting the belt drive; not difficult, just a lot of fiddly fabrication. The systems are easier to make, but he'll just buy existing Rover ones if they're not too loud. Plenty of V8 cars about to decide on that, and if they are we'll make them too.
My reply was in Dave's direction ;)
I was pleasantly surprised by how relatively straightforward wiring an LS lump into an Omega. ;)
That MG project looks to be a well thought out one that should improve markedly over the original offerings 8)
Quote from: Nick W on 08 April 2019, 19:01:17
Having messed around with some Rover V8s and then messed around with some Omega V6s my subjective impression is that the Omega is LOUD.
My theory is that the Rover is in a low state of tune and has pushrods slowly opening one exhaust valve per cylinder whereas the Omega is overhead cam and can open two exhaust valves per cylinder a lot quicker (and let the noise out faster).
My opinion is that everyone makes exhaust systems far bigger than is necessary for the power output, and then fit silencers that don't. My Metro is only 145hp, yet the system is 2" which is good enough for 200hp. It's not only loud but the sound is horrible.
As each system on the MGB will only have to deal with 100hp, 1.5" pipes will be plenty especially if we fit two big silencers in each side. Using that size pipe means tighter radius bends, which makes it easier for tight fitting systems. It's a road car, a cruiser and it needs to be quiet.
I think the hardest task is going to be finding somewhere under the car to locate silencers with enough volume to provide significant attenuation.
The single thing which provides the biggest drop in sound level is linking left & right systems together - easy on a Range Rover but probably impossible in an MG :-\
Quote from: Nick W on 08 April 2019, 18:16:11
Not Smiths Instruments? Am disappoint.  :P ;) ;D
Quote from: aaronjb on 09 April 2019, 08:57:58
There's a guy near me that makes very nice looking Smiths instruments that actually work have modern electronics behind them IIRC.
EDIT: Not sure if his firmware simulates that wobbly speedo needle when travelling at less then 20 MPH though. ;D
 ;D
Smiths have their own stepper driven range now - have done for a while AFAIK.. it's what I have in the Cobra. If I ever finish wiring the damn things in. So many wires, so little space.
Quote from: Kevin Wood on 09 April 2019, 10:39:31
Wobbly speedo needle?.........a sure sign you are at the wheel of a British classic. :y
